Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
D-Board How do you take the D-Board off of a Sony KP-46WT500?
  • Anonymous Feb 21, 2008
    We got a new D-board and we are trying to unhook the red wires from the old flyback transformer without breaking them.
  • Vista Electronics May 11, 2010
    Be glad to help.....What is the symptom and what is your
    diagnosis?........................T.
We got a new D-Board and we are trying to unhook the wires from the old flyback transfomer without breaking them.
Posted on Feb 21, 2008
How to go in service mode for tv sony kp-46wt500.i did change the stk ic,the convergence is good in the midle but bad on the side
Did you replace the pico fuses on the G board there are two and usually one will blow when the old ICs fail and just replaceing the two ICs on the D board will usually not fix the issue untill the two pico fuses are checked and the blown one is replaced.
Mar 20, 2012 | Sony KP-46WT500 46" Rear Projection...
BLUE SCREEN My sony KP 46wt500 hdtv ready rear projection has
Ur tv have a problem known as convergence problems.Ur tv convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
Jun 06, 2010 | Sony KP-46WT500 46" Rear Projection...
Sony kp 46wt500 has 3d screen what might the problem be?
If convergence out ICs got defective then TV shows that kind of picture.
Replace IC8001 and IC8002 on D Board, both big black ICs are mounted on aluminum heat sink and number STK392-560 would be written on it.
Required ICs are available in Part Store, click that link to see an image of IC and price info.
If you are not comfortable with soldering parts in circuit board, call local tv tech to replace it.
Thanks.
Nov 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Replace ICs on Sony CRT
Since the IC's need to be unsoldered from the board you should have a professional servicer do it for you,there is always a chance of lifting a solder trace.If that occurs then you will have major problems.
May 01, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46 in. Rear Projection HDTV-Ready Television
If the D board didnt correct the convergence issue the problem has got to be the wave generator on the A board or possibly the Velocity boards themselves that are bad.
Jan 16, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony Projection TV KP-46WT500 Convergence Problem and Sparking
You may want to get some help with this install...goto www.tvrepairkits.com and ask for some help
Jan 14, 2009 | Sony KP-46WT500 46" Rear Projection...
Appearing rainbow colour for sometime and getting off.
There are few cold (dry) solder joints in convergence board of your tv Sony KP-46WT500
Please inspect convergence board and resold dry solder joints.
Oct 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence
Hi
The stk392-560 is convergence correction amplifier, the 4.7ohms 1/2watt resistor is the attach in convergence board! but before you replace this parts you need to check if good or bad parts!
Thanks!
Oct 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500
you need to replace both convergence Ics number STK392-560 its a fairly easy repair that requires basic soldering skills. you can get replacement Ics with free instalation instructions with pictures at the following link,
http://servicemanuals.vstore.ca/
May 25, 2008 | Sony KP-46WT500 46" Rear Projection...
HELP, Please!
pict tube probably shorted and damaged tda 6120 video drive ic also 4.7 resistor on blue crt drive board now open .
May 08, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
