Question about LG LRTP1231W Top Freezer Refrigerator
The freezer makes a whistling noise most of the time,only stopping for a short time and then starts again.
  • LG Master
  • 1,711 Answers
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
Posted on Sep 15, 2010
Brand new Kenmore mini fridge is making an annoying whistling noise
If Sears did suggest a solution for the symptom you describe it would probably be to replace the fan.
Nov 21, 2013 | Kenmore Refrigerators
Whistling noise freezer close
Hello sangpark003 - Often when the unit is making a whistling noise, it is because it is pulling air from the outside. Sometimes a poor door gasket could be causing the whistling. You may check if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. However, if issue persists, I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts or to confirm if it is a normal operation noise.
Mar 28, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hp M551 laserjet printer makes whistling noise when printing
Some times the toner has a clear plastic tape that is inside the toner, the tip is on the short side of the toner cartridge. if you do not remove that plastic then it would make that whistling nosies.
Jun 05, 2012 | HP LASERJET ENTERPRISE 500 COLOR M551DN
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
Apr 18, 2009 | GE Refrigerators
2001 Monte Carlo - brakes squeal "whistle"
Actually - I had the same problem and replaced my brakes 4 times in a year. YES 4 TIMES because of the whistling. I switched from metallic to ceramic pads and works like a charm! Ceramic will not allow the noise, plus I have found to have much better control over braking and short distances.
Jan 14, 2009 | 2001 Chevrolet Monte Carlo
Freezer whistling noise
I assume the noise is only there when the compressor is running.
This can be caused by the expanding coolant/gas that removes the heat from inside the cabinet passing through a restriction in the coolant tubing.
It may be annoying but unless the unit isn't doing what it should, I don't think this is harmful.
Dec 15, 2008 | Refrigerators
Wind whistle noise
To determine what's making the whistle, try putting some tape over anything that might be causing it. I'd tape over any trim or moldings to try and find out where its coming from. You might try a wide roll of tape over the window edges, and trim points, if the whistle stops, take off a section at a time and recheck until it appears again, and you know what's causing it. Try to keep the tape flat, or you might create some new whistles! Let me know how you do. countrycurt0
Sep 04, 2008 | 2004 Hyundai Tiburon
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
LG LRTP1231W Top Freezer Refrigerator Logo
295 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
