Washing machine sounds like a loud air plane onthe spin cycle
  • Washing Mach... Master
  • 8,220 Answers
Bearing
Posted on Feb 03, 2010
  • Dan Webster
    Dan Webster Feb 03, 2010
    Special tools are required to replace the bearing.
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Jul 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
May 26, 2010 | LG WM-1832C Front Load Washer
Noise and movement when spinning
Could be more than 1 problem by sounds of this. !st may be that heater is not working and so machine will not advance to rince. As for banging this could be caused by pump failing to take water away. Or on a more seriouse note could be drum or bearings. Normally if bearings have gone then it will sound like a plane going over. I think it is likely heater, or /and pumping failure.
Mar 15, 2010 | Washing Machines
Spin cycle is loud
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | Washing Machines
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Problems with MAV9501EWW Washing Machine :(
your seals and bearings are bad do you wash a lot of sandy gritty clothes if you do that is the cause of the problem
Jan 19, 2008 | Maytag Atlantis MAV9501E Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
