Question about Craftsman Rear Mount Tiller
I had to repair pull cord, in doing so I took the throttle linkage carborator linkages off to get to the pull rope housing. I need schematics to show all the throttle control springs wire hook up to get carborator linkages back right. The motor is running at high rpm and I can not get it to throttle down. model 917 293650 sears 6.0 eager-1 craftsman Thanks, Dave
    Problem Solver:
  • 16 Answers
Go to sears.com and look up the actual engine number. they have a section for lawn and garden and in there there is a link to their parts lookup and they are very detailed. but you will need a pulse tach to set the govenor back to where it was and if it spun the govenor open too far due to the govenor not being hooked up, it could have came apart inside the motor and you will need to take it to a shop. as far as setting the govenor once you get it all back together, you need to push the throtle wide open and turn the govenor shaft in the same direction then tighten it down. yeah its not hard if you have done it before but if you havent and cant understand what i just said, save your time, and engine and have a shop fix it. and i havent seen a motor in my 9+ years that you had to remove all of that to fix a recoil rope.
Posted on Feb 04, 2010
How do i fix a broken pull cord
take off any plastic covers, take off pull rope housing, take out old pull rope tie a knot at the end of new rope to be installed. wind rope housing counter clock ways to tighten the spring up. when it stops turning back of one turn. line up the hole on the plastic wheel with the hole on the side of housing and push new rope through. pull rope till the knot seats in the knot hole. put rope handle on and the covers. there are many videos that will show you how to do this on you tube. good luck.
Feb 05, 2016 | Garden
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
1980 suzuki gs550 Which is the throttle linkage and which is choke linkage?
The choke linkage moves back and forth left to right.
The throttle linkage is in the center of the carbs and pulls a pulley that turns the throttle butterfly plates.
Jun 22, 2014 | Motorcycles
How do i replace the throttle body linkage bushing
Follow The Hose From The Air Filter Housing It Goes To The Throttle Body Assembly.... Then Follow The TV Cabe From The Transmission To The Throttle Body Linkage The Grommet Usually Brakes Causing The Transmission Not To Shift Correctly Or Not At All.... The Grommet is Pressed Into The Throttle Body Linkage Pretty Simple Fix!!!!
May 19, 2014 | 1988 Lincoln Town Car
Throttle linkage diagram
maybe someone took off the linkage cable what you need here is
to find a schematic of your unit and that should tell you where everything goes on the unit .you should be able to download a
schematic from the web!
Nov 09, 2013 | Garden
I have a porter cable 5250 generator that bounces off the governo
there 2 linkages that conect that would be the problem. you have on conected to the throttle switch that runs to the govener than on that govener os another linkage hooks up to it and runs to the carborator that ajusts the flow. if you don't have both linkages than you need to order 1.
Jun 14, 2009 | Coleman Powermate Powermate 5000W...
Chevrolet sprint 1986 idling high trying to find the
If the vehicle is a carborated engine, you would find your vehicles throttle body where the linkage connects for your acceleration. Most engines then have the idle screw very close to this linkage. Though from what little photo's I have seen of the vehicles engine compartment via google images. I unfortunately can not direct you as to where the throttle body on the engine is located.
Apr 14, 2009 | 1986 Chevrolet Sprint
2003 F250 super duty 4x4 no throttle
did you check the linkage?. if the linkage is ok your tps(throttle position sensor is bad. you need to replace it. it is located on the throttle body housing is black in color and has (2) bolts that hold it in place there is a weatherproof plug with (2) wires. hope this helps yah out. please rate this
Sep 01, 2008 | 2003 Ford F250 Super Duty Crew Cab
Tecumseh 6hp engine
I have a 6hp tecumseh mower. "Centura Le". I prime it it runs..stop priming and it dies. I think it needs a new fuel pump/or filter. I can't locate on mower, will you advise?
Thank you
Jul 11, 2008 | Karcher 2500 PSI Pressure Washer
Craftsman Rear Mount Tiller Logo
237 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
