Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
Good morning, I am trying to set up my voip (magicjack) on a DIR-655 wireless and I can send call but cannot receive them. I am not on the LAN as i am wireless, can you help
    Brigadier General:
  • 10,406 Answers
You _are_ on the LAN -- via your "wireless" connection.
However, the "unsolicited" TCP/IP traffic caused by the "incoming" call is being blocked by the firewall software inside the D-Link router.
Follow the MajicJack instructions for "port-forwarding", so that all that unsolicited traffic gets "forwarding" to the IP-address that is assigned by the router to your computer.
Posted on Feb 03, 2010
655 and charter
To setup your D-Link wireless router follow these steps.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 20, 2013 | D-Link Xtreme N DIR-655 Wireless Router
I have a D-LINK DIR-655 in use. It was fully functioning up until yesterday when wireless suddenly stopped broadcasting. The wired connections all are functioning properly , but no laptop or other device...
Try resetting the router back to default settings. Press and hold the reset button for 10 secs. then release. After the reset, try accessing 192.168.0.1 once again and check if you have the complete details on your wireles LAN section.
Sep 03, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Why does my LAN work through my D-Link DIR 655 router, but not my Wireless? It is detectable by various PCs but none are able to connect to it.
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped.
Feb 07, 2011 | D-Link Xtreme N DIR-655 Wireless Router
My dlink dir-655 lose connections every few minutes, no idea why? Can someone help??
This could be because of the security settings not being compatible with the unit trying to obtain an IP address.
I would suggest taking the wireless security off completely to see if the problem perssist and try using the highest security possible.
Good Luck
Nov 20, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Using DIR-655 as hub, DHCP disabled, 3 PCs connected with LAN cables, and LAN cable from modem which is DHCP server, all works fine, including HP wireless printer. But when 4th PC connects wirelessly,...
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Sep 18, 2010 | D-Link Xtreme N DIR-655 Wireless Router
CAN NOT GET INTERNET FROM DIR-655 TO NS7000S
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
One of my LAN and wireless network computers has no Internet
look this happens if go to your internet explorer and check if you have your internet working offline if you have it checked uncheck it
Sep 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
DIR-655 does not allow Avaya VOIP phone to work
You need to check the DHCP configuration on your router. Also try setting up a static IP on your VOIP phone & try.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Not broadcasting
Try reconfiguring your wireless setting from your router. Create a new wireless network. The old setting may had been corrupted.
Dec 29, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
102 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
