Amilo A7600 - where do I install two upgraded RAM
Fujitsu Siemens Laptop Amilo A7600 - where do I install two upgraded RAM chips to replace the existing one?
    Brigadier General:
  • 10,406 Answers
Turn off your computer.
Disconnect the AC power.
Remove the battery.
Take a small screwdriver.
Open the access-door on the bottom of the computer.
You'll find the existing RAM chip.
It's held in place by two "fingers" -- one at each end.
Push the two fingers "away" from each other, and the RAM chip will partially lift away from its slot.
Remove the chip.
Look for two "slots" for RAM.
Put the two "new" sticks into the two slots.
Push down on the RAM until those "fingers" click, and hold the RAM in the correct position.
Posted on Feb 03, 2010
Testimonial: "This was partly helpful; what I anm not sure of is when I remove the existing RAM will I find two slots in that position for the 2 new RAM chips? "
  • ikkenom Feb 28, 2010
    When you remove the one stick of RAM, notice that the stick has a row of gold connectors along one edge. Look at the socket where those gold connectors were connected -- you may see two side-by-side sockets -- like "upper" and 'lower" bunk beds -- or you may see two sockets -- like matching goal-posts at each end of a football field -- in that "bay" that you have exposed, by removing the cover.
    If you don't see two sockets, remove the one RAM chip, and reconnect the cables, and start-up your computer, and see if it "beeps" (due to _NO_ RAM being detected) or if it reports that you still have some RAM (64MB?) because it's possible that the motherboard itself has some integrated _NON_-_REMOVABLE_ RAM, and only the _ONE_ RAM socket for _ONE_ stick of RAM.
Hello I have laptop Fujitsu-Siemens Amilo Li 1705 It's no display on screen With 5 beeps 1-3-1 I am replace ram but no worked
If you remove the hdd, ram and dvd drive. Power up and then shut down. Place one ram chip in the slot, (ensure correct type and value). Is the error still there? If it is possible GPU issue.
Jan 05, 2016 | Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
Hi, I would like to upgrade the original 512 MB memory. We have just found the second slot (just under the keyboard!!!) and now I have the following question: can I keep the old 512 MB RAM module and...
What type of RAM is your Pc using? SDR, DDR1 or DDR2? 1 GB single module of RAM maight be heavier for your notepad and the Laptop maight even fail to boot. Just use the 2 Modules of Ram (2 chips each 512MB) and check in BIOS if the RAM capacity has acually changed.
Rgds
Nov 04, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
What CPU could I fit to the Amilo pro V2010 to improve performance
Before you consider changing the CPU consider upgrading the RAM you can install 2GB of DDR in that laptop it will certainly run faster.
Be carful to get DDR not DDR 2, go onto the crucial RAM site and run the test software it will tell you exactly what you need and how much it will cost around £60.
If you haven’t got 2GB in the laptop I would certainly try that first.
Hope this suggestion helps.
Nov 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
How to change and upgrade the memory Fujitsu-Siemens Amilo Pro Fujitsu-Siemens Amilo Pro V2010
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
Nov 18, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu-Siemens Amilo Pro V2040 Laptop memory locations?
Sorry, This laptop only supports one memory card slot upto 1.7GB
Mar 15, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Which memory ram for amilo pro v7010
http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
Jan 31, 2009 | Computers & Internet
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
546 people viewed this question
David Payne
David Payne
