Question about Kenmore Washing Machines
On the ultra clean cycle,the washer will fill with water but then stops@ there is no agitation kicking in.
  • Kenmore Master
  • 8,220 Answers
That is probably the lid switch. I have some repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 03, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
    it seems to me ur washer transmission is going out or already there
    Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
    Fills, washes, but won't drain or spin
    Possible your outlet filter is blocked, it needs periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first.
    Jun 13, 2007 | GE WWSE5200B Top Load Washer
    Washing Machines Logo
    22 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
