Question about Zodiac Pacer Pool Cleaner
Pacer does not run on INTEX pool pump, no pulsating action of diaphragm, pump sucking OK, Auto Weir Valve connected, pool 1,20m deep, round, 4,88m diameter
  • 366 Answers
Make sure to check the diaphragm inside, check for deformity or debris stuck in it. You can take the unit apart just below the wagon wheel and push the white tube downward to expose the diaphragm.
Posted on Feb 03, 2010
How to adjust suction in a barracuda pacer
there is a flow meter for use with these units to ensure proper flow rate. if this tests in range, make sure there are no obstructions in the hose or cleaner. if there is still a problem, it might be time to change the diaphragm in the cleaner
Jun 18, 2014 | Zodiac Pacer Pool Cleaner
Pacer not "chugging" or moving around the pool. I
the pump may have a plugged up impeller or internal part wear , i need to know what type of pump yu have, also a plugged filter may be the cause
Oct 28, 2011 | Zodiac Pacer Pool Cleaner
Our zodiac works for a while then stops. The moment you lift it, it starts sucking again and goes for and while and stops! Check the filter basket, backwashed, checked the weir all seem fine - now what...
check in internal diaphragm for deformities or debris. un-thread the nut at the top of the unit and push the white pipe downward, when you pull it out of the bottom of the unit, check the condition of the rubber diaphragm. should only have a narrow uniform opening. if its wide open or deformed, it may be causing you some problems.
Aug 16, 2011 | Zodiac Pacer Pool Cleaner
Our Zodiac Barracuda pool cleaner isn't working
you may have a bad diaphragm inside the unit. Unthread the nut between the "wagon wheel" and the lower unit and remove it, push down on the white tube until it comes out of the bottom of the barracuda. Inspect the rubber diaphragm for debris and deformations. If the diaphragm has a large gap inside, it won't work properly. It needs to have only a small uniform gap, they can sometimes even look completely closed when they are new. Replacing the diaphragm will most likely make the unit run like new again.
Nov 14, 2009 | Zodiac Pacer Pool Cleaner
My new Pacer is sucking but doesn't move around the pool
check for debris inside the diaphragm. also check to see if the diaphragm is distorted, the sides of the **** should be parallel and should not have a huge gap or hole. You can check it by unthreading the stem just under the "steering" wheel, then push downward on the white tube and it should come out of bottom of the unit, the diaphragm will be connected to the white tube. Inspect and replace the diaphragm if needed.
Sep 21, 2009 | Zodiac Pacer Pool Cleaner
Zodiac pacer
Sounds like diaphragm is ripped
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
May 31, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Pacer Pool Cleaner Logo
106 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
