Question about RTO Atwood DSI-RV Water Heater-6 Gallon
Hi: I have a atwood-6-gallon heater, the pilot works well but when I try to switch over to the main burner the pilot goes out time after time --- only used once. Thanks in advance Jim
  • 196 Answers
This can be caused by a number of problems.
1. How long has the pilot been lit before you turn it to burner? It needs to warm up the end of the coupler. When you push in on the knob to light the pilot, hold it in for a while after the pilot lights. This allows more gas/hotter pilot flame to warm things up.
2. How fast are you turning it to burner? You need to do it really slow. The gas is under pressure and can blow out the pilot if you do it too quick.
3. Is there a blockage in the tube? Lady bugs, spider webs, etc. can cause a blockage and this problem. It's pretty common. (A long pipe cleaner will clean it out in a few seconds.)
If all of these fail:
4. It it getting too much/too little air? Check the air gap in the end of the tube. (Also called air manifold)
Posted on Feb 03, 2010
Electronic burner lights then goes out in a few seconds
I am not sure about your particular heater but the thermocouple on a full-size gas water heater is often the cause of a pilot failing. It is relatively inexpensive to change (or mine was). It is a simple metal tube with a wire that is located near the pilot to tell the burner that it is ok to come on because the pilot is lit.
Nov 25, 2013 | RTO Atwood DSI-RV Water Heater-6 Gallon
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
Hi, I have a Atwood 91043 (Model 37C14U-5). The pilot and main burner seem to work fine (main burner ran a couple minutes then shut down) but I'm not getting hot water at the facet. I have the...
Have you checked back of water heater for proper valve positioning? (by-pass may be on)
Cold water enters through bottom fitting and hot comes out the top. Any valves in between should be closed and any valves going in bottom and out top should be open.
Jun 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
MAIN BURNER WILL NOT IGNITE
Any RV sales and service dealer can get parts for you, if they don't already have them in stock. Is the pilot staying on at all? If yes, what happens when you turn from pilot, to On? One easy thing to try is undo thermocouple (probe that sits above pilot flame) from gas valve (3/8" wrench) and clean the end of the thermocouple with fine steel wool, as well as spray some WD-40 into the hole it came out of, and give it a blast of compressed air after to clean it out as well. (protect your eyes) Then re-install the fitting and snug it up good, and try lighting again. You may get lucky that it's just corroded or dirty, and this may cure that.
Jun 07, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
The pilot light blows out every time the main burner shuts off. It will light, the main burner comes on, everything seems ok until the main burner shuts off, then the pilot light goes off also as if the...
it's the thermocoupler ( about $20 ) that is bad replace it. if that doesnt do it it is the box with the on/off/ pilot button ( about $175 ) I found a complete unit at www.americanrvcompany.com for $275 plus shipping ($300 total) and that is how i fixed the exact problem with mine.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Electronic ignition tries to lite, clicks 5 times, then goes POOF
Gas burners go "poof" when they have too much gas in the area upon lighting. This is normally due to the ignition source not being close enough to the initial source of gas. This is normaally corrected by ensure the main burner is clean so that it distributes the gas correctly and having the ignition source at proper strength and location. I would have to have good schematics of your heater to be more specific. I hope this helps.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
225 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
