Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat
The lights comes on, the plate turns and the fan comes on as well. It just won't heat any food My GE microwave has stopped heating. Everything else works.
  • GE Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
I would first suspect a failed door switch or loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 27, 2008
  • 2,336 Answers
It looks like the magnetron failed on your microwave.
This something that you may be able to do it yourself, just need to keep some good safety measures when it comes to the high voltage capacitor.
This may be the magnetron for your appliance: http://cgi.ebay.com/OM75P-GE-Samsung-Microwave-Magnetron-Tube-WB27X10017_W0QQitemZ170195128083QQihZ007QQcategoryZ150140QQcmdZViewItem
Good Luck.
Posted on Feb 20, 2008
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Microwave stopped heating. Everything else still works - it comes on, the light comes on and the plate rotates and it dings when it done, but te food is still froozen.
Sounds like either the magnetron or its high voltage power source has failed.
It is extremely dangerous to work on the magnetron side of the power system. It CAN and DOES KILL!
Dec 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Microwave will not heat any thing.
the plate has nothing to do with the microwave heating up the food
but the magnetron that heat the food is bad and will need replacing
I would ask a electronic shop how much they would charge to replace it , and if is not worth it to you then a new one would be a good call
Dec 01, 2008 | GE Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
216 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
