Question about Microsoft Xbox 360 Console
Xbox 360 video problem
Full audio: no video though
tried to remove all cable and reconnect and on diff. tv's
problem still there
i think it may be an overhaeting issue due to being on top of dvd player and amplfier
  • 1 more comment
  • dheivinrojas Feb 20, 2008
    xbox 360 no video,sistem pal
  • charlzilla Feb 23, 2008
    i borrowed a friends cables and my xbox still dont come on; i think it may be something else like maybe the video processing chip cracked or sumthing
  • Anonymous Mar 29, 2008
    i just got my xbox back from the repair center after school so i played from 4-10. then next morning my hdtv said "mode not supported" but i can hear the audio. now they are sending me a coffin.
    Problem Solver:
  • 13 Answers
In case it is overheating, you should move the 360 into open space when it is on. Those things can get pretty hot, especially when on for long periods of time.
However, it is more likely that there is a problem with you audio/visual cable (the three pronged thing). Check for any breaks in the cord, or the prongs themselves. The metal pieces can become detached. If this is the problem, buying a new cable is the best option, and wont set you back too much.
There is also a switch at the base of the cable (where it plugs into the xbox) you should make sure it is set to TV and not HD-TV. That could also cause the problem.
Posted on Feb 20, 2008
  • Tzark Feb 20, 2008
    I also forgot to mention that though the cable may look fine externally, there could still be a break in the connection inside. If nothing fixes the problem and the cable looks fine, i still recommend buying a new one because of this. Sorry for the confusion.
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
Have XBox 360 Elite and Voyetra Turtle Beach X11 Headset. Got new 3D HD TV and when I attached the HDMI cable to the XBox the headset stopped working. I have been told it is because the cable has an...
I myself have a 46" RCA LCD flat screen tv, which I have my xbox 360 connected via HDMI cable. If your tv has audio out "rca plugs", which im sure being a newer 3d HD tv, connect the supplied cable to the audio out (red, white) plugs, and then connect your headphones to that jack!
Dec 31, 2010 | Voyetra Turtle Beach Ear Force X11 Headset...
When I am switching on the xbox I am getting all four red lights on with flashing.
Disconnect and reconnect the AV cable. If that does not work, you can try a friend's cable. If that works, the cable is shot, if not the 360 needs a service or, well, that cable is shot too!
May 05, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays game but recently has no sound? tried diff powercord and diff tvs still same problem. help
try a different av cord.yellow,red,white cord or what ever cord that goes to your tv.sometimes the cord gets broke where the audio is at and sometimes the system has a setting where it won't project sound
Jun 30, 2009 | Microsoft Xbox 360 Console
What to do if tv screen goes green and blue when i put halo3 in x
for this type of issue,it could be the DISC,AV CABLE or the CONSOLE itself.
TRY THIS:
• try using a diff game disc with the same title.if it worked,buy a new disc
• if using a diff game disc wont work, try using a different AV cable (the cable that connects the console to the TV)
• if still doesnt work.process a repair for the console at service.xbox.com or call xbox support hotline for phone assistance,you can also check further troubleshooting steps at xbox.com
May 16, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 repair
TRY GETTING A NEW PIECE TO PLUG INTO TV. ALSO TURN ON TV BEFORE CONSOLE. IT HAPPEND TO ME. I DONT KNOW WHY THOUGH.
Apr 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 - While setting up in menu the TV went black and msg. No Sync. Signal
First, make sure you select either TV or HDTV selector on the Audio Video Cable that came with the XBOX. Second, if you chose TV plug the Audio/Video Cable connectot that are red, white , and yellow in color to your TV. Now see if you can see the Start up on the XBOX360.
If you still dont get anything, try plugging it on another television and see if that fixes your problem.
Dec 09, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
