² Coupe
² Sedan/wagon
2. Open the hood and disconnect the headlamp wiring socket from the
in-line connector. This will make it easier to change the bulb.
3. Remove the protective dust shield
from the housing by turning the
dust shield counterclockwise (when
viewed from the rear).
4. Release clip and disconnect the electrical connector from the bulb.
5. Remove the bulb retaining ring by
rotating it counterclockwise.
6. Without turning, remove the old
bulb from the lamp assembly by
pulling it straight back out of the
lamp assembly and replace.
7. Install the new bulb in lamp assembly by pushing straight in with the
bulb’s plastic base facing upward. Turn the bulb slightly to align the
grooves in the plastic base with the tabs in the lamp assembly.
8. Install the bulb retaining ring over the plastic base and lock the ring
by rotating it clockwise until it snaps into place.
9. Connect the electrical connector into the plastic base until it “snaps”.
10. Install the protective dust shield and lock the shield by rotating it
clockwise until it locks into position.
11. Connect the headlamp wiring socket to the in-line connector.
12. Turn the headlamps on and make sure they work properly. If the
headlamp was correctly aligned before you changed the bulb, you should
not need to align it again.
__________
Testimonial: "Thanks! I knew it would be something simple but for the life of me, I couldn't figure it out. Thanks so much!"
SOURCE: routing of serpentine belt for ford escort zx2
Click on the link below, Enter the year,make,model, and engine. You will get a page with a link to the diagram you need under the part number.
Greg
http://www.mvreader.com/multiview/dayco/index.php?autoCatalogSearch=0&catalog=auto&l=n&year=2000&year_from=&year_to=&make=FORD
SOURCE: how do you change the headlight in a 2000 ford
Under the hood - follow the wires to the back of the headlight assembly. Separate the connector and remove the lock ring around it. Coax the bulb out - it is held in with a rubber ring. Note the position - the new bulb will only go in in the same position. Replace the lock ring and the wire connector.
SOURCE: How do you remove a headlight 'assembly' (not the
You have to remove the front bumper cover. Put the car on jack stands (the front) and remove the inner fender plastic. You'll need a long extension and a 10mm socket to remove the nuts and bolts holding the bumper cover in place. Once the cover is off removal of the headlight becomes obvious.
