TV won't show external device in colour
Hi
We have had this tv for 4+ years but for some reason we have never been able to play video from a camcorder or games from a PSP on it in full colour. For example, when I attach my camcorder (with correct to attachment) and play footage it's always in black and white, the same with PSP games - the only appear in black and white. I've made sure I've attached all leads correctly, but still no go. I can play all external equipment on other TVs in the house OK, but not the LG one (which is our main TV).
Can you please suggest a solution.
Many thanks.
Kate
  • 111 Answers
Sounds like your using rca jacks yellow red white you need to use componet green blue red then red and white for audio
Posted on Feb 03, 2010
Manual for sharp camcorder model VL-E760U.
I HAVE A PROBLEM WITH THIS CAMCORDER, WHEN I CONNECT TO VIDEO INPUT OF MODERN DVD RECORDER TO RECORD FROM 8 mm T6APE TO DVD DISC THE PICTURE THOSE NOT SHOW PROPERLY IT SHOWS QUARTER OF THE PICTURE . WHEN I CONNECT DIRECT TO TV COLOUR TO PICTURE SHOWS IN ALL SCREEN, CAN YOU SUDJEST SOMETHING FOR THIS PROBLEM?
BEST REGARDS
FRANK PLEVEN.
Feb 12, 2011 | Sharp VL-E760U Camcorder
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
I've had a number of vcrs and vcr/dvd players over the years. But for some reason, I cannot set up this machine. I set up all of the cables exactly like I always have and the way that is instructed, but I...
These days the video input channel depends on the TV and any other equipment in the sequence. I've seen component video come in as Line, Channel 3/4 (with a switch on the video device), Aux1, Ex1, AV1, Channel 60 (I think that may be specific to satellite dish receivers). If the remote has an input button, try that (alternatively, look in the menu for source options). One thing to try: press the PSCAN button on the DVD remote (to toggle off the Progressive scan).
On some TVs the channel for the video is reached by going down from Channel 2 (this works when no channels are programmed into memory and the intervening channels are skipped).
What TV are you connecting to the DVD/VCR player? (If it is an older TV and any external device was connected to either channel 3 or 4, check that the TV works with any input device. I had a 19 year old TV (coax in only) that was damaged and no external device worked.)
I wish that I could be of more help.
Apr 26, 2010 | RCA DRC8335
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
Cannot copy video from JVC GZ-HD6 camcorder to DVD Recorder
If you can play the vision on your tv via an av connection you should be able to record it onto the recorder. the recorder can record anything thats being played on the tv even if the other device is connected to the tv via another av connection. try this & see if it works.
Mar 14, 2009 | JVC GZ-HD6 HDD Camcorder
PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Jan 16, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Playback on external device.
The SV-AV100 and the SV-AV50 come with an A/V cradle that allows you to connect to external devices for recording and playback. The SV-AS10 and SV-AV25 are not equipped for this operation.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
