Question about Acer AL1715 17" LCD Monitor
When wiping off the keyboard with the computer and monitor on some combination of keys must have been hit and the screen display is now sideways. How can I return it to normal view?
Thank you, I did fix it by holding the control & alt keys and using the arrows to align the screen.
Posted on Feb 04, 2010
I touched a button on the keyboard that turned the page sideways.. it turned it to the left. how do I turn the page right side up?
Actually you hit a combination of keys. Most likely you hit Ctrl+Alt and an arrow key. Try Ctrl+Alt+the up arrow. If that rotates the screen to upside down, repeat the combination twice more (or use Ctrl+Alt+the down arrow twice).
If that doesn't work, if you have a Windows OS, try the Screen Resolution or Graphics Display settings. Right click on the desktop anyplace with no running programs or icons, select Screen Resolution and then change the drop down for Orientation. This works on my desktops. For my laptop, it's the Graphic Display and then a similar orientation label.
I hope this helps.
Sep 10, 2013 | Logitech Y-RAZ71 Wireless Multimedia...
Sideways page fix
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.Restore by pressing Ctrl-Alt plus the up arrow key.ALSOTo change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.Some computers do not have this function.
Mar 04, 2012 | Compaq Computers & Internet
My screen is on sideways and i cant put it back the right way
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
Dec 02, 2011 | Computers & Internet
I was dusting my acer monitor and microsoft wireless keyboard and i must have hit something because now my monitor is reading sideways and the mouse wont work with it either. Can you tell me what I need to...
Sounds like you changed the orientation of your display settings from landscape to portrait.
In Windows 7 you can go to the control panel, choose display and click "Change Display Settings" on the left side.
From there choose the "Orientation" dropdown and change to your desired setting (most likely landscape)
Good luck
May 12, 2011 | Acer AL1916W 19" LCD Monitor
Screen display is sideways
Hi all5r_mine,
Based on your situation. I suggest trying the following options:
Upside Down or Sideways Monitor Display
Problem Description:
The user accidentally pressed a keyboard combination that turned the entire monitor display upside down or sideways. The user cannot recall the keyboard combination that caused the problem and has no idea how to rectify the display.
Possible Solutions:
Some graphics cards have rotation "hot keys" enabled by default and this is probably the most common cause of this problem. The exact procedure for rectifying the display may depend on the particular brand and configuration of the graphics card in the problem computer. One of the following options may help resolve the issue.
Option One:
Try using the keyboard combination, "Control + Alt + Up Arrow Key". Control + Alt along with one of the arrow keys is a fairly common rotation hot-key configuration and may just do the trick.
Option Two:
If Option One doesn't work, see if there is a graphics card icon displayed in the Notification Area (near the Windows Clock). Clicking (or right-clicking) the icon may reveal a "Rotation Settings" option that will allow you to revert to "normal" display.
Option Three:
If neither of the previous options help, try the following procedure.
1. Right-click an open area of the desktop and click "Properties" to open the "Display Properties" window.
2. Click the "Settings" tab and then click the "Advanced" button to open the monitor settings window.
3. Click the tab corresponding to your graphics card. You may need to click one or more buttons within the tab to reveal a rotation settings option. Exactly where rotation settings are located will depend on the brand of graphics card installed.
4. Once you locate the rotation settings, choose the "0 degrees" or "normal" option to change the display to upright. The rotations settings may also give you the option of disabling rotation hot keys so that the problem does not happen again.
5. Click "OK" to save changes and exit out of any open properties windows.
Navigating through menus and choosing options when the display is abnormal is difficult but certainly not impossible.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Acer Computers>Laptops Aspire 5610-2013 PC...
The screen is turned sideways
It sounds like you accidentally press the key combination to rotate the screen. This is a feature on some video cards to allow portrait display with the right monitor. Your monitor does not rotate so the picture is sideways. To correct this problem simply click CTRL + ALT + Up Arrow and your screen should return to the correct orientation.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 22, 2010 | Dell E173FP 17" LCD Monitor
Monitor display is sideways not vertical
with some graphics card you can rotate the display try pressing ctrl and the alt key at the same time and while doing this hit the arrow key (or direction) that u want the bottom of the screen... so if u want ur screen upside down, hit ctrl alt and the up arrow
Aug 13, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
I have a emachine 4010. Monitor display sideways
hold alt+ctrl then click the up arrow while holding alt+ ctrl
May 08, 2009 | E-Machines T5048 (7136) PC Desktop
Acer AL1715 17" LCD Monitor Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
