I my frontload frigidaire doesnt spin but i do hear the motor running
    Brigadier General:
  • 3,917 Answers
Hi
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician to deal with the problem.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 03, 2010
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Drum not spinning! Already replaced motor, but still not working.
possibly the door llatch/ switch assembly thing i know that was common on some frig frontloads.. big grey or black thingie
Jan 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Drains but will not spin. I can hear the motor
The machines spin motor winding may be short circuited kindly replace the motor
Dec 23, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Gallery Series Frontloader no final spin
I had the same problem. Here's a link that might help:
http://applianceguru.com/forum2/2937.html
I removed the hoses and pump and found the filter in the hose leading from the washer was clogged with a shoelace, $2.35 in loose change and a few GI Joe issued M4's. :-) Once I pulled that filter out and cleaned the **** the washer runs like a champ.
Apr 30, 2009 | Washing Machines
Frigidaire Frontloader 417.39022890
Hi thanks for the question. I would look at the pump. remove bottom panel. pump on the right, remove hoses, clean out the pump. thanks the appliance doc
Oct 07, 2008 | Estate TAWS800JQ Top Load Washer
Non-spinning washer
Do you hear the motor running when it doesnt spin? Is the belt still over the idler pully between the drive pully and motor pully? Does the lid switch operate properly? Need a little more information if you can. Give me a shout back, and we'll figure it out. Jim
Oct 31, 2007 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
