Question about Moen & One Handle Tub & Shower Faucet
I have installed a MOEN one handle faucet in a new bathroom shower. Last night when I finished plumbing the cold water (the hot is not yet finished) I noticed there was a slow drip in the bathtub. Nothing I could do woud turn the water on or off?
  • 105 Answers
You need to have both done before any judgement is made, the balancing spool could be off centre because of only one water being hooked up. good luck
Posted on Feb 05, 2010
Make sure the safety plastic ring is adjusted right...if not it won't allow water to get hot enough
Posted on May 16, 2012
No hoy water coming out on Moen shower faucet?
If you have hot water elswhere in the bathroom but not the shower head then the diverter valve in the handle for the tub is most likely bad and needs replaced. The diverter is also called an anti scauld valve, it mixes the hot and cold water to prevent scaulding you in the shower
Oct 02, 2011 | Moen Home
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Mar 01, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Plumbing
Hi rbyerly,
I'm Harvey the Master Plumber.
Your problem is:
remodeled bathroom,installed new moen valve and hardware. Now water is coming from both the shower head and the faucet when the diverter is in the down postion. Question; Is this a single handle or three handle diverter? Assuming it's a three handle, it should just be a mater of adjusting the center handle. If single, the diverter is in the spout not the valve. I don't know how to direct you further without specifics. Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Home
Moen & One Handle Tub & Shower Faucet  Logo
352 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
