Question about Dell Optiplex GX110 (2909T) Motherboard
DELL Optilex GX110 - RAM
I installed 2 banks of RAM (KINGSTON SDRAM DIMM RAM 256MB PC133 133MHZ 168PIN CL3) on my Dell Optilex GX110, but switched the pc can not turn! Should be compatible ... you have any advice?
    Brigadier General:
  • 10,406 Answers
Put the "old" RAM back into the computer, to see if the PC will work at all, or if you damaged the motherboard when you were changing the RAM, or if you accidentally disconnected some cables or jumper-blocks.
Posted on Feb 03, 2010
Can i use a ddr ram in a dell latitude c600 notebook
hi simply NO this is sdram as here are the specs for this laptop Memory Architecture SDRAM Memory module sockets two user accessible SODIMM sockets Memory module capacities and type 64-, 128-, and 256-MB
3.3-V SDRAM SODIMMS 1 Standard RAM 64-MB memory module Maximum RAM 512 MB Memory clock speed 100 MHz Memory access time CL2 or CL3 (Note: CL3 indicates a CAS latency of 3 clocks) BIOS address F000:0000-F000:FFFF
hope this helps
Jan 10, 2011 | Dell Latitude C600 Notebook
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
Physical Memory is limited to 256 MB" in dell 2600 poweredge
In the bios there is an option to install OS, make sure this is flaged as off, when you reboot you will have access to the full amount of onboard ram.
Aug 20, 2009 | Dell PowerEdge 2600 Server
Dual Channel for DDR os not function
The problem might be your ram are not dual channel. Dual channel ram are usually matched in pairs in speed and size of modules ( 2 modules of 1gigs or 2modules of 512). Check out crucial technology site in the support section either F&Q or live chat with them....Doc
Oct 11, 2008 | Abit KN8 Ultra Motherboard
CHILL WILL'S (motherboard E210882) WOES!!!
It seems like you have done everything right but im not 100% sure that your memory is correct. read through the description here carefully and you will see that this memory comes in two different packages. One of them is the 400 (the ones you bought) and another in the 333 flavor. I am hoping they did not make a mistake and gave you the wrong ones. Look directly at the memory and make sure. I am also including the system manual for your computer. Hope this helps.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
Kingston's ValueRAM KVR400/1GR is a 128M x 64-bit (1GB) DDR400 CL3 SDRAM (Synchronous DRAM) memory module. The components on the module include sixteen 64M x 8-bit (16M x 8-bit x 4 Bank) DDR333 SDRAM in TSOP packages. This 184-pin DIMM uses gold contact fingers and requires +2.6V. The product is shipped in retail packaging and includes installation instructions.
Apr 27, 2008 | Dell (E210882) Motherboard
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Ram memory upgrade
1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
Feb 25, 2008 | Areca ARC-1210 Serial ATA Controller
Cant boot up Computer- Memory address line failure
From the failures its probably a RAM memory problem , which means that you should try a different ram module that is working , or if possible try the ram module of this pc in another one thats working.
Aug 30, 2007 | Dell OptiPlex GX110 PC Desktop
Dell Optiplex GX110 (2909T) Motherboard Logo
135 people viewed this question
Alun Cox
