Screen is blank when turned on but works with external moniter
    Brigadier General:
  • 10,406 Answers
Probably, the "LCD inverter" has failed -- take the laptop into a dark room -- do you see a FAINT image of your "Windows desktop"?
If so, it's a $20 part to replace, but rent a qualified technician (1 hour @ $60/hour) to safely and properly replace the inverter.
Or, spend $200 to replace the LCD (plus $60 "labour").
Posted on Feb 03, 2010
BLANK LED SCREEN ON STENTURA 8000
plug in a moniter if you get a picture the screen has gone ,new screen or use with moniter
Nov 13, 2013 | Computers & Internet
I have an acer aspire 5536 and when i turn it on, its either a white screen or a black screen. I have connected it to an external moniter and the computer works fine. Ive used the functon button with f6...
have you got the screen output on 2nd monitor only ?
hold down windows key it is right next to FN key and press P
also you may have changed the settings to make the second screen the defeult screen . (not sure how to change this just remember seeing it as an option in settings)
Mar 05, 2018 | Acer (9005210464), (64 MB) Graphic Card
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
My screen to my laptop dose not work what do i do
if its totaly blank , the first thing you should try is connecting it too an external moniter, that will rule out motherboard or graphics card problem if you get a display to an external moniter
Mar 02, 2009 | Toshiba Satellite M35X-S311 Notebook
Laptop screen
Have you tried hooking up an external moniter? If so do you have video on that moniter? If you do have video on the external moniter then you most likely have a bad inverter or a bad lcd panel.I would replace the inverter first because it's not very expensive.If that doesn't work then you can replace the lcd panelAnd if that doesn't work you have problems at the system board level.
Dec 15, 2008 | Compaq Presario M2000 Notebook
PROBLEM WITH DELL INSPIRON 1000
Well it seems that the system is running but there is no display on the screen.To confirm that try connecting a external moniter ot the system and see if you get the display on that.Also try hitting the NUM lock key and see if it turns on and off as well.After connecting the external moniter if you see the display than there is an issue with the screen and incase u still do not see the display than there could be an issue with the video card.So incase you still have the warranties on the system you call the dell tech support and get the parts replaced.
Hope this helps!
Anuj
Jan 04, 2008 | Dell Inspiron 1000 Notebook
My Toshiba laotp's screen goes half blank help!!
Well try to boot into the safe mode.hit F8 on the startup and see if you get the same acreen.If its working fine in safe mode than you need to reinstall the video driver and that should resolve the issue.If it is still not working try connecting a external moniter.If you get the same display on the external moniter than its an issue with the video card and if you get a normal display on that than its an issue with the Laptop screen and you would ahve to get either of thses replaced by contacting the manufacturer.
Hope this helps!
Sep 17, 2007 | Toshiba (225EXTR5)
24 people viewed this question
k24674
jasbo
jasbo
