Question about Dishwashers
Water does not recirculate, takes water in and heats it up okay
Water does not recirculate after taking water in, heating element works okay. Could it simply be the recirculatory pump or something simpler (and therefore cheaper)?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    I'd suggest you re-post with additional info, such as: 1. Brand of dishwasher 2. Model number 3. Does the recirculating motor run after the unit fills? 4. Does the dishwasher pump the water back out when it normally would? 5. Does it make any noises, other than the inlet of water? 6. How old is the dishwasher, and how long have you had this problem? Has it worked before or never worked?
  • 51 Answers
There may be a shard of broken glass stuck in the wash pump, this is very common. or it may be the capacitor that has worn out. try gaining access to the wash pump and with a slotted screw driver, turn the shaft at the back of the motor, if it turns freely, with EXTREME CAUTION, start the machine up and when the motor should be running, turn the shaft with the flat screw driver and if it runs as normal, replace the capacitor, that will solve your problem. If on the other hand the motor is jammed when you initialy turned the shat, there will be glass or something similar stuck in it. hope this has been beneficial to you.
pallesappliancerepairs.com
appliancesdav@hotmail.com
Posted on Feb 03, 2010
I have fractional spa pump with 1000 watt heater. the spa was on but no water was in it while it ran overnight. did this burn the heat elements out of it and can I fix it?
It should be OK. These units should have a flow switch to prevent activation of heating element without water flow. Yes, heating elements can be relatively easily be changed if needed.
Dec 08, 2014 | Comfort Line Products Spa2Go Inflatable 4...
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
Heater not working
if you set for a temp warmer than water is now if it wont heat up see if menu shows its calling for heat if not temp sensor if so sounds like bad heating element also is recirculation pump runnig and are your filters clean?
Apr 03, 2014 | Pool & Spa
How do I replace the heating elements in my Rheem water heater
Replace heating elements can be found at amazon, click here and take a look: Amazon com rheem heating element . I hope this was helpful... cheers
Jan 31, 2013 | Rheem 82V40-2 Fury Electric Residential...
Model 587.14134102 dishwasher is not cleaning well. Unpon checking it by opening it up during various cycles the water does not seem hot enough. The dishes are warm to the touch but not hot. How can I...
Does your machine take in hot or cold water. If it takes in hot water the element that heats and maintains the heat may be defective. If it takes in cold water the element is heating it but the thermostat is cutting out the element at too low a temperature. Normally dishwashers take in cold water and heat it to the required temperature, which would mean that the thermostat is faulty?
Feb 06, 2011 | Kenmore Dishwashers
I recenty purchased and installed a Whirlpool electric water heater model #E2F40RD045V, when the lady of the house wants to take a shower the hot water doesnt stay hot the whole time. The water heater is a...
Sounds like one of your heating elements is not heating properly.
Check to make sure you are getting power to both of the heating coils, you can check that by removing the two covers over the heating elements and checking with an electric ohm/volt meter for power to the elements. If you have power going to both elements then you will need to check the elements themselves.
Unplug the water heater and then check the two heating coils to make sure they have continuity across the two terminals. You probably will find only one is working, replace it with a new element and enjoy all the hot water you can use.
This is a FREE answer, Please rate me
Dec 05, 2010 | Home
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
W6021 will not heat water, but will continue to wash a complete cycle. It does take over 3 hours to complete one cycle. I have changed the temperature select module.
Sounds like heating element, should read around 30 ohms on multimeter if okay, if faulty will take forever to do wash...Good luck
Sep 29, 2009 | Asko W6021 Front Load Washer
Whirlpool Dishwasher ADG7540/1
an ntc is very reliable. have you checked continuity thro the heater? other common fault is a dry joint devoloped on the control card - take it out and check for dry joints
Oct 02, 2008 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
