Question about Kenmore 24032\24036 Top Load Washer
Locking mechanism is broken off - machine will not power on.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Feb 03, 2010
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
Power lock does not work on rear door
Power door lock mechanisms required periodic lubrication to work correctly. Without periodic lubrication, the mechanisms stick and, eventually, the lock solenoid will fail and require replacement. As a rule, the power lock mechanisms and power window regulators should be lubricated every two to three years.
Begin by removing the door panel and lubricating all points of the lock mechanism, including the solenoid plunger. If that does not correct the condition, look for broken parts and mechanical obstructions. Manually move the solenoid plunger to make sure that the mechanism is not seized. If the mechanism will not move, detach the mechanism from the actuator solenoid and see if the solenoid itself has seized.
Check that the lock solenoid is receiving 12V when the LOCK/UNLOCK button is actuated. If not, trace down the electrical fault. If the mechanism moves freely, and there is voltage at the connector when the switch is actuated, the solenoid has burned out and should be replaced.
Jul 23, 2014 | 2005 Dodge Caravan
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Jun 11, 2011 | Kenmore HE3T Washer
What is error dL f
Doorlock error.
F dl Door lock error
I have a service manual and more HERE
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
F-22 is my error code. What is that?
F22 DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Nov 25, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Display says F dl
Hello there
Here is the meaning for the code and what you should do ok
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
Jan 07, 2010 | Washing Machines
Won't start and the display alternates between dl and f
Hi. This is a Door lock mechanism failure code.
2. Check door switch/lock unit. Make sue it is mounted correctly, and not loose.
If the door lock unit is mounted correctly, and the wires that link the device to the main control module, and connected well, this will lead to a failed lock mechanism. replace the door lock mechanism, in this case.
Nov 18, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a code DL flashing on my washer
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU). If the wiring is ok, replace the door lock mechanism.
Oct 17, 2009 | Kenmore Washing Machines
Says FL and won't run
3. Check the wire harness connections to the door switch/lock unit and Main control board.
If the wire harness is ok, replace the door lock mech.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
353 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
