Question about Kenmore Dishwashers
A broken plate has small pieces slogging the pump. How can i clean it out?
Klarspüler
Posted on Feb 03, 2010
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
Feb 26, 2015 | Baby Lock Imagine
Samsung DMR78 dishwasher makes a grinding noise at the beginning of the wash cycle as well as the rinse cycle. Also comes up with the code 9E on occasion.
Check the brackets that hold the top rack for any broken plastic brackets. My dishwasher was making the same noise and after noticing the broken plastic pieces I pulled out the dishwasher put it on its side removed a white panel on the bottom that is attached with two screws, removed the drain line and inside there were two plastic tabs from the broken bracket. Once those were removed the grinding noise stopped. The bracket holding the drain hose can be removed with a pair of pliers.
Jan 01, 2011 | Samsung DMR78AHS Builtin Dishwasher
The agitator and tub will not turn. Does this indicate broken motor drive coupling assembly?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Oct 22, 2010 | Washing Machines
Icemachine is going into harvest prematurely.Why is this happening?
the grate under the evap plates have been known to break off small pieces. These pieces get caught in the discharge of the pump and hold open a spring loaded valve which then let water out and tricks the float into a harvest.
It's the white triangle piece with 3 screws in it usually just about or next to the pump. Look for broken pieces inside of it. Remember, when you take it apart, it's spring loaded.
Aug 04, 2010 | Hoshizaki KM-630M Crescent Cuber Ice Maker
Starts slowly in wash and spin, then increases has a slight noise when starting. could it be the drive motor?
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It's possible (though unlikely) that it's the motor. I'd check the following first.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
If the coupler looks damaged, (plastic prongs broken or rubber center piece holes broken) it's a relatively easy fix.
Jun 28, 2010 | Kenmore 22062 Top Load Washer
My kenmore serie 80 will only agitate with a small load not a full load, what could cause this?
May 17, 2010 | Kenmore 24032\24036 Top Load Washer
How to remove motor from washer. How to remove cabinet, pump, motor, and motor mounting plate to inspect and replace the motor coupler.
Mar 25, 2010 | Kenmore 24032\24036 Top Load Washer
Mar 25, 2010 | Kenmore 22422 Top Load Washer
Series 80 washer quit spinning;makes a whir sound instead .model#11028802890
You have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28802890
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. You would also hear a sound from the two plastic pieces rubbing togetner.
With the transmission out of the washer, I'd also check the clutch for wear or broken springs.
Sears has a "rebuild kit" for the clutch if it is damaged.
Oct 19, 2009 | Kenmore Washing Machines
I have a husky compressor, model number y6010-wk. it builds pressure slow, and shuts down right away.
Problem: My compressor is not producing the air that it once did. It takes twice as long to pump up.
Solution:
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
4)Remove the head off of your pump.
5)Remove the valve plate off of your pump. It may be a one piece or a 2 piece design.
6)Inspect the valve plate for broken reed valves or broken gaskets above or below the valve plate.
Feb 27, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Dishwashers Logo
46 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
