Question about EliteGroup K7AMA Motherboard
I lost my manual and need instruction to connect my mother board to a new cse
Need instruction to connect k7ama in a case
  • 46 Answers
Hi there!
You can download the English manual for K7AMA(ATA133) PCB V1.5 manual from here:
Have fun!
Brad Nelson
Posted on Feb 20, 2008
Had to put my motherboard in a new case, and i have tried to follow the manual but i am still lost as the pc is not powering up? i think i have connected everything correctly but still not getting power,...
make sure the aluminum tower is covering black chip on mother tight with metal clasp on alumnium tower is covering chip make sure fan is properly tight on mother board make sure battery in mother board is in and make sure fuse is in mother board then restart push f2 and start your reboot....
Feb 17, 2011 | Foxconn 760GXK8MC-RS Motherboard
Lost book on mother board and i accidently pulled the case wires from the mother board. need to reattach in order for the mother board to have power and thus the computer to power up.. need to see...
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Jun 11, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Power connections for tower led's
The manual in question can be located here
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Front pannel connection on the mother board d815eea2 motherboard
Hi Billy, please use the manual to help guide you. Turn to page 33. If you no longer have the user manual please download it from this link:
You will need adobe reader to view the manual. You can down load adobe for free at this link:
Or directly from Adobe.
On pg. 3 is a picture of the motherboard's front panel pin connections. Item "C". (Front Panel pin to case LED's).
Armed with this information (Pictures), you can plainly see the pin numbers.
Page 4 shows you which is positive + & which is negative - pins.
Do not be fooled by the manual name. Intel often groups like motherboards into one manual. This manual does cover Intel's D865GV & D865GVHV motherboard. The second toughest thing to do is find which case wires or positive & which are negative.
This changes from case to case. Look at all your front panel wires. Most common ground is white in color. Positive wires are colored except internal case's speaker 2 wire. Black is negative.
Good luck Billy!
Hope you find this helpful.
Aug 08, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Usb problem
Apr 16, 2008 | Computers & Internet
Well i had the same problem... i got a new pentium 4 board but it could not get fitted in the casing.... so what do you do is take the casing to a welder.... he will cut off a piece of metal which is resisting the mother board... The maximum loss is that 2 slots of CD ROMS will become obsolete and i think you dont need have fun
Dec 13, 2007 | Computers & Internet
K7ama2 USB cable wire unplugged
the comon colors for usb are [red +5v] [white data -] [green data +] [black ground] and you need pinouts on your mother board also you may have 2 jacks so there is a 9 pin connector on board for external usb jacks, just get the manuel for it on internet but I need the motherboard number and make
Dec 12, 2007 | EliteGroup K7AMA Motherboard
EliteGroup K7AMA Motherboard Logo
327 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
