Question about AudioBahn A3651 CD Player
Hjow to unlock my stereo audiobahn a3651
How to unlock my stereo audiobahn a3651
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
Does an audiobahn A2801Q throw 1000 watts
Hello... I can help you with this question. This particular amplifiers specifications are as follows:
  • 200 watts x 2 @ 4 ohms stereo
  • 280 watts x 2 @ 2 ohms stereo
  • 560 watts x 1 @ 4 ohms mono
    These specifications are RMS power, which would mean continuous "real" power output. Hope this helps!
    20 year car audio/video installer
    Bay manager
  • Mar 15, 2011 | AudioBahn A2801Q Car Audio Amplifier
    Is the audiobahn a2801q 1 ohm stable in bridge mode?
    No it is not. You will melt that amp trying that. It is only good for 4 ohms mono and two ohms stereo.
    Aug 21, 2010 | AudioBahn A2801Q Car Audio Amplifier
    Security code for A3451
    does anyone have the security code for an audiobahn A3451 CAR STEREO
    Apr 28, 2009 | AudioBahn A3451 CD Player
    Loud thumping noise
    ok u hava pero in solb u us mlifayr
    vich wat ok and 2 chanl 4 chanl 8 chanl 16 chnal us platal mi
    Mar 06, 2009 | AudioBahn AK402 Car Speaker
    Amp a2801q
    Audiobahn A2801Q
    Product Description:
    Class A/B MOSFET Circuitry
    Volt Meter With Blue Illumination
    PWM MOSFET Power Supply
    Double Sided Glass Epoxy Circuit Board
    THD: 0.02%
    S/N Ratio: >100dB
    Frequency Response: 10Hz - 40KHz (+/- 1dB)
    Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
    Variable 18dB Low-pass Crossover: 30Hz To 120Hz
    Bass boost @ 45Hz: 0/18dB
    Subsonic Filter: 20Hz to 50Hz
    RCA Throughput Connections
    3-way Protection Circuitry: Thermal, Short Circuit and Overload
    Cooling Fan
    Cobalt Blue Illumination
    High gloss Chrome Plated Finish
    Nickel Plated Block Terminals
    Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
    1-year warranty
    Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
    Hello
    Hi Colmen,
    The unlocking code should be printed somewhere on the manual or other documentation that came with the stereo. The alternative to this would be to take it back to the reseller where you bought it & ask them if they have a decoding service. If not then try your local car audio specialist as many offer this service for only a small sum of money.
    Dec 18, 2007 | AudioBahn AK402 Car Speaker
    I have lost my security code
    I need the security code for an audiobahn a3651 car stereo
    Nov 05, 2007 | AudioBahn A3651 CD Player
    Baffled
    AudioBahn A2401Q Car Audio Amplifier: 100 watts x 2 @ 4 ohms stereo 140 watts x 2 @ 2 ohms stereo 280 watts x 1 @ 4 ohms mono ZT3000 "Beta tester of "0"s and "1's"
    Aug 25, 2007 | AudioBahn A2401Q Car Audio Amplifier
    AudioBahn A3651 CD Player Logo
    98 people viewed this question
    Top AudioBahn Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Colin Stickland
    Colin Stickland
    Jerry Naidoo
    Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
