Question about Brother Office Equipment & Supplies
When faxing with brother the mfc 440 cn do you fax with print up or down
  • Brother Master
  • 3,594 Answers
Make a copy to see if it copys with the print up or down, the fax works the same way.
DickyO
Posted on Feb 03, 2010
Is is possible to go back two weeks to see a journal report on my brother mfc 9440 cn series? I didn't save a confirmation page and I need to see confirmation of a fax sent two weeks ago. Thanks
  1. Press the Menu key.
  2. Press the Up or Down Arrow key to select Fax and press OK.
  3. Press the Up or Down Arrow key to select Report Setting and press OK.
  4. Press the Up or Down Arrow key to select Transmission or XMIT Report and press OK.
  5. Press the Up or Down Arrow key to select the option you prefer.
    • Off
      Transmission verification report will print only if a fax transmission is unsuccessful.
    • Off+Image
      Transmission verification report will print only if a fax transmission is unsuccessful with a portion of the fax's first page printed on the report.
    • On
      Transmission verification report will print after every fax transmission.
    • On+Image
      Transmission verification report will print after every fax transmission with a portion of the fax's first page printed on the report.
  6. Press OK.
  7. Press Stop/Exit.
May 10, 2011 | Office Equipment & Supplies
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Brother 465 CN Won't pring in fax mode
It's all part of the setup that's in your manual. If you use the menu, go to reports and print the user settings you can check if it's set to hold faxes in memory or to print right away. It's all done by user selection.
Oct 02, 2009 | Brother MFC 420CN All-In-One InkJet...
How do I delete the memory from a MFC-440 CN printer?
Menu
*Fax
*Advanced Fax Operation
*Fwd/Page/Store
*Off
Stop /Exit
Page 81 Brother manual
Sep 09, 2009 | Brother MFC-440CN InkJet Printer
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
Printing fax
take the paper tray out and shut the machine down also cancel out any printing in the cpu then reboot the printer good luck
Jan 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC 440-CN out of memory error, fax memory is full I cn't send any more faxes, I called Brother tech support they told me that there is no way to clear the memory, that I had to leave the printer unplugged...
Try this :
To resolve this situation do the following:
1. If another operation is in progress (example: receiving a fax,
printing, etc), press STOP/EXIT, wait until it's completed and then try
again.
2. Clear the machines memory. This can be done by turning off Advanced
Fax Operations.
a. Press MENU.
b. Press the UP OR DOWN ARROW key to choose Fax.
c. Press OK.
d. Press the UP OR DOWN ARROW key to choose Advanced Fax Operation.
e. Press OK.
f Press the UP OR DOWN ARROW key to choose Fwd/Page/Store.
g. Press OK.
h. Press the UP OR DOWN ARROW to choose Off.
i. Press OK.
j. Press STOP/EXIT.
If received faxes are left in your machine's memory when you change the
Advanced Fax Operations and a backup copy has already been printed, the
LCD will ask:
Erase All Fax?
Yes - Press 1
No - Press 2
Advanced Fax Operations and a backup copy has not yet been printed, the
LCD will ask:
Print All Fax?
Yes - Press 1
No - Press 2
# If you press 1, faxes in the memory will be erased or printed before
the setting changes.
# If you press 2, faxes in the memory will not be erased or printed and
the setting will be unchanged.
k. Try your operation again.
Good luck...
Nov 11, 2008 | Brother Office Equipment & Supplies
Problem with my fax Machine MFC 420CN
You can cancel a fax job that is stored and waiting in the memory.
1 For MFC-210C,
press Menu/Set, 2, 5.
For MFC-420CN,
press Menu/Set, 2, 6.
Any jobs that are waiting will appear on the LCD.
2 If you have more than one job waiting, press ▲ or ▼ to select the
job you want to cancel.
Press Menu/Set.
—OR—
If you only have one job waiting, go to Step 3.
3 Press 1 to cancel.
To cancel another job go to Step 2.
—OR—
Press 2 to exit without canceling.
4 Press Stop/Exit.
That should do it for clearing faxes you dont need you can also print off all the faxes in the memory and I believe that clears it.
Enjoy,
Lee
Jun 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Using MFC 420 CN;
yes, face down on the glass. it will scan first then send the fax.
Jun 05, 2008 | Brother MFC 420CN All-In-One InkJet...
49 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
