Question about Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum
The hose works but not the brushes
I can use the hose but when i try to stand it up and vacuum the brushes arent going round
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
The brush bar, properly called a 'disturbulator' (seriously, it is!) runs off a belt aroung either the center or one end of the bar, the belt then passing around a pulley on the motor, said pulley being part off the 'fan' blade which provides the air flow and creates the suction. If the belt is okay, possibly some 'fluff' or carpet fiber has wrapped aroung the slot on the bar or the groove on the pulley, causing the belt to slip and the disturbulator not to turn.
Posted on Feb 03, 2010
Why is the brush not going round
Hi there, it's Jack at Dyson.
As with many Dyson vacuums, DC25's cleaner head is protected by a sensor which shuts off the brush bar if something jams it. If the brush bar isn't currently rotating the machine may need to be reset - this is simple to do after you've checked the cleaner head for obstructions, and removing any threads or hair from around the brush bar and end cap. Please follow the steps shown in the video guide below:
When you've completed these checks and reassembled the vacuum, plug it back in, recline it into the normal vacuuming position turn it on and press the silver brush control switch (next to the red on/off switch) twice. The brush bar should start to rotate - please note, the brush bar will never rotate when the vacuum is standing upright.
In the unlikely event that you continue to have issues with the cleaner head after giving this a try, please get in touch with our experts so we can provide further assistance. If a repair or a replacement part is needed, we can also confirm if your machine is still within its Dyson guarantee. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 15, 2015 | Dyson Bagless Upright Vacuum DC41 Animal
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
Forever series hose is clogged
Turn the sweeper upside down and stand it on the handle then take a screw driver to unclog the nozzle behind the roller brush. If the rest of the hose is clogged then you may have to take it to a sweeper repair store to get it cleaned.
I would try a straightened out coat hanger and CAREFULLY work it around to try to break the clog. If you're not that handy then go to an Oreck store if you have one.
Nov 27, 2013 | Oreck Vacuums
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
Hi my dyson is not sucking up very well when i put it on its side and switch it on the brushes are not going round when i put the white dail to on at the bottom the brushes go round but it makes a terrible...
Sorry to hear you're experiencing a problem with your cleaner. Please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US). We can run through some checks over the phone and provide you with the assistance you need.
Kind regards,
Jack
Dyson Customer Service
May 17, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a dyson dc all floors and I need a new bottom brush, will I be able to replace it myself without breaking any plastic parts,if I order the brush online?
i would say to take it into a shop. Don't try it yourself Dysons arent any vacuum you can just go into target and buy for 50 bucks. there not made to just be taken apart.
Sep 12, 2009 | Dyson Vacuums
Can't get it to ****!!!
Worked on one with your same problem of poor suction and won't stand up. On the left side of the handle, near the bottom, the port cover isn't on correctly. Take it off, put the handle in the upright position then reinstall the cover.
Mar 29, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum Logo
81 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
