Question about Delta & Single Handle Shower Faucet
How do i get the retaining collar loose..it wants to turn the entire pipe
    Scholar:
  • 81 Answers
The retaining collar in my nomenclature for Delta is the ring that holds the cartridge into the valve. If we are talking apples to apples, there is no reason for it to be difficult to unscrew. A good firm grip and average strength turning counterclockwise has always been sufficient, but there are exceptions to everything.
Posted on May 29, 2010
The bottom roll of laminating film will not remove.
most likely, someone has unscrewed the thumbscrews in the right side "collar". Best thing you can do is loosen both thumbscrews on the both collars, push the film on the shaft as far left as you can. then tighten both screws back down as tight as you can by hand. then grab the film and push the entire assembly to the right as it's spring loaded to the right. once it clears the keyed shaft holder on the left, just lift up and out. the right side collar screw should never be loosed. it just causes problems. West Laminating Svcs. 405-324-6092
Sep 28, 2015 | Gbc HeatSeal Ultima 65 Laminating System
How do I remove a fuel tank from a 2004 Buick Rendezvous
First of all, there is a recall for gas tank replacement for your vehicle. The dealer will replace it free. The link will get you to the document in PDF form
Redirect Notice
It looks like there is a bracket on one end of the tank hidden by a heat shield
FUEL SUPPLY SYSTEM Fits Buick Rendezvous
Feb 08, 2015 | 2004 Buick Rendezvous
The exhaust on my rear cylinder is making excessive noise, i'm not complaining but on inspection, the manifold is split, it seems to have made out of 2 pieces! why would any1 do that??? shoud i replace...
Muffler putty, no. If you have it off, take it to the local welder. They can tell you if it is fixable. Usually your best bet is to just spend the money and order a new original equipment replacement part (if a good salvage/used part is not available. Be sure to replace the exhaust gasket in the head when you put the pipe back on. EBAY may be a good source of a good used head pipe.
Sep 27, 2011 | 2000 Suzuki VL 125 Intruder LC
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
Aug 23, 2011 | Roland Cube-20x (20w 8" Modeling Guitar...
How to replace 2002 pt cruiser starter
2.4L Non-Turbo Engine
Remove or disconnect the following:
Negative battery cable Air cleaner box cover Engine structural collar Starter electrical connectors Starter To install:
  1. Install the starter and torque the bolts to 40 ft. lbs. (54 Nm). Attach the starter electrical connectors.
  2. Install the engine structural collar on models with a automatic transaxle as follows, refer to the illustration for bolt locations:
    1. Place the collar in position and hand tighten the collar to transaxle bolt.
    2. Position the power steering hose support bracket and install the collar to oil pan bolt.
    3. Place the bending strut in place and hand start the bolt.
    4. Install the bolt through the strut and collar and hand tighten.
    5. Place the power steering hose support bracket in position and install and hand tighten the remaining bolts.
    6. Tighten the collar-to-transmission bolts to 75 ft. lbs. (101 Nm).
    7. Install the bolts through the strut and into the block.
    8. Tighten the remaining bolts to 45 ft. lbs. (61 Nm).
  3. Install the engine structural collar on models with a manual transaxle as follows, refer to the illustration for bolt locations:
    3. Position the clutch slave cylinder into position and hand start the bolts.
    4. Tighten bolts (1) to 75 ft. lbs. (101 Nm).
    5. Tighten bolts (2 and 5) to 45 ft. lbs. (61 Nm).
    6. Tighten bolts (3 and 4) to 20 ft. lbs. (28 Nm).
  4. Install the air cleaner box cover and connect the negative battery cable.
2.4L Turbo Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner box cover Upper starter bolt by pushing the inner cooler up and out of the way Inner cooler lower hose from the inner cooler Nuts retaining the inner cooler tube Studs retaining the power steering lines Position the power steering lines aside Engine structural collar Starter electrical connectors Starter
To install:
  4. Install or connect the following:
    Power steering lines aside Studs retaining the power steering lines and tighten to 45 ft. lbs. (61 Nm) Nuts retaining the inner cooler tube Inner cooler lower hose to the inner cooler Upper starter bolt by pushing the inner cooler up and out of the way. Tighten to 40 ft. lbs. (54 Nm). Air cleaner box cover Negative battery cable
Jul 03, 2010 | 2002 Chrysler PT Cruiser
How do you take the headlight out of 1998 ford taurus se?
Use a screw driver to release the plug retainer on top. Remove plug. Turn collar 1/8th turn to remove. Wiggle bulb and pull back. Do not touch the glass of the new bulb. The oil on your skin is enough to shorten the life of the bulb.
Push new bulb into place being sure the retainer is on top. Reinstall collar and plug wire.
You may need to remove the battery to get enough room for your hand on the driver side and the two hoses on the passenger side.
I just did it and it is relatively easy.
Nov 11, 2009 | 1998 Ford Taurus
My chuck on my drill will not close
Could be couple problems, the jaws are sticking or the chuck retaining screw is loose jamming up the jaws. If the jaws are sticking you can try some WD 40 and run the tool in for/rev holding the collar with gloves and see if it loosens up or if the screw is loose it is a LH thread. Let me know if you need more assistance.
Sep 18, 2009 | Drills
How to reassemble header for 2002 Kawasaki Ninja 250
first lay out all your exhaust system parts . take inventory.2 ex. gskt.2 mffler gskt,left muffler(short),right muffler(long), header pipe,4 collars, 4 nuts(6 mm),2 holders,2 muffler clamp,2 hanger bolt,2 nut( 10 mm). next. put small dab of grease on exhaust donut gaskets so they will stay in place by themselves when you stick them in place in the exhaust ports ,on the cyl. head.next gather collars, head pipe w/ holders & 6mm nuts, w / 10mm .wrench or socket.tricky part,hold head pipe up in plce to head,take collars w/ lip or bend facing out & put in between pipe holders & ex. donut gaskets,place holders over exhaust studs & install 6 mm nuts & tighten evenly but do not tighten all the way just keeping collars in place. now hang mufflers,w/ gaskets,clamps,nuts, & bolts,loosely.now tghten down head pipe evenly,cheking collars for proper alignment as you tighten.next,tighten mufflers to headpipe w/ clamps using 12 mm socket or wrench.next, tighten mufflers to frame using 14 mm.finally, start bike & check for exhaust leaks.
Feb 14, 2009 | kawasaki Ninja 250R Motorcycles
Never had a portable, put connector on tap and it blasts off when turn on water
I am assuming that you have the appropriate adapter on your faucet.
You are not actually getting the connector attached to the faucet.
Pull down on the locking collar while lifting the hose connector onto the faucet adapter.
When the connector snaps into place, release the locking
collar.
Turn the hot water on slowly until it is all the way on.
Sep 16, 2008 | Dishwashers
Delta & Single Handle Shower Faucet  Logo
260 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
