Question about Roper RAS6233KQ Top Load Washer
The agitator is loose and "clunks" as it is washing. How to fix?
    President:
  • 2,468 Answers
Remove the agitator cap on the top of the agitator and check the 7/16" nut securing the agitator to the transmission shaft
Posted on Feb 03, 2010
  • 5,911 Answers
You may have a worn agitator cam assembly, worn agitator dogs, or a loose agitator bolt.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to access and/or replace them. It also explains how to access the bolt and tighten (if necessary):
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number for the dogs are included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you aren't sure, or have additional questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
2 Suggested Answers
  • 74 Answers
SOURCE: kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Posted on Oct 03, 2009
Agitator went loose. How to fix it
REPLACE THE CAM DOGS IN THE AGITATOR, EASY FIX AND PARTS ABOUT 5 BUCKS
Oct 12, 2014 | Amana Washing Machines
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
Clothes wrap around washing machine agitator causing it not to spin
clothes wrap around agitator. making clunking noise only while agitator is working
Feb 19, 2011 | Washing Machines
While it is agitating there is a loud clunking
I had the same problem and fixed it today. all you have to do is take a putty knife and on the front of the washer, just under the top there are two clips that hold the front on. the top doesnt need to come off at all. the clunking sound means that at some point the washer was perhaps overloaded and is now bottoming out when it gets to a certain point in the agitation. take a pair of pliers and rebend the silver mounts in the front corners where the tub is suspended
Nov 28, 2009 | General Electric WJRE5500GWW Front Load...
Kichenaid kawe570bal0 agitator clunks
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
During the regular and permanent wash cycles, there is a clunking noise...the machine is agitating, but sounds terrible. What is the problem?
Sounds like a loose transmission bolt on frane mount. You may want to look and see. The test is to run with half a load. Roll over this drawing at the bottom of the tub and a popup will say"Transmissiom" follow it down and you will see "damper padds" You may want to concider another machine because you can buy a used one for less than what it would cost th fix it also I don't know if you want to get that involved working on it. Sorry My vote is for a new/used maching.
Aug 12, 2009 | Maytag Washing Machines
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
214 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
