Question about Miele 300 Front Load Washer
How to change door rubber on miele premier 300, can the front of machine be opened allowing to change the door rubber
    Habit-Forming:
  • 37 Answers
I'm assuming you mean the flexible rubber between the door and the drum. Can it be replaced? The short answer is no! However...
I recently repaired a door rubber with a tear that caused the water to flood onto the floor. Here's how:
Yes, you can open the front to get to the door rubber however the rubber seal is glued to both the door and the inner drum lip.
You may have to tilt the machine on it's back to remove three screws from the underside of the front lip. (I forget if you need to take the water pump cover out as well but it wouldn't hurt to do so.) This allows the front panel (including door) to drop down a quarter inch or so and be eased out a little.
This allows *better* access to the drum rubber. To repair a tear - really the only reason you would want to do this - you need glue and some tape.
The door rubber is silicone and will stick with normal 'super glue'. However, bear in mind that these machines can do a wash up to 95C, which is hot enough to soften superglue.
I found a new version of superglue called Repair Extreme by Pattex that copes with temperatures up to 120C. It sets in about 5 minutes.
The glue needs to be flexible. Do not use epoxy resin.
I gave the glue some form by sticking a 10-15cm piece of duct tape - the silver shiny plastic tape plumbers use, readily available from any hardware and most supermarkets - to the *back* of the drum rubber. It's a tight squeeze to get your hands in there but it can be done.
Take the tension off the drum rubber by moving the front panel roughly back in place.
Then squeeze a generous amount of glue along the tear (about 3cm long on the bottom edge; a typical problem) to completely whet the edges to be joined.
Apply a little pressure to the location of the tear for a few minutes to help the glue hold fast. Leave the glue to set for at least half an hour before reassembly.
If you can source a replacement drum rubber the old one can basically be removed by force. A good cleaning and then a suitable glue could stick a new unit in place. However, if this is required, seriously consider buying a new unit. It is difficult to make a good seal that will not leak and may not be worth the effort in the first place.
Posted on Jul 30, 2010
Loud thumping noise in spin and smell of rubber with smoke when door opened
there are diffrent kinds of front load units some have rotor and stator issues you sound like yours has motor with belt possible bad belt or motor.
or its shaft and bushing is going.
Nov 02, 2012 | Miele Novotronic Premier 500 Front Load...
How do I open my Miele W504 and change the motor brushes
Hi Kieron
Open door then turn off power. Undo 3 bolts around door seal. Remove soap draw. Undo the screws. Peel off door seal at front of machine and fold in towards drum. Metal spring catch located at bottom behind pump filter door. Now open up front of machine (its hinged on the right). Good luck
Feb 19, 2012 | Miele Novotronic Premier 500 Front Load...
We have a Miele W701. We just finished a load of laundry and the door won't click open. The electricity is on and I cannot see any other problem with the machine.
The most common cause for this problem, is the Electro Magnetic Door lock, itself. The part may cost about $170, new. However, you can open the door manually, from the bottom side of the washer. Other causes may be a defective "push button switch," or drainage problem. In a drainage problem, water sitting inside washer, won't allow the user to open washer door, until the water is manually drained out. Good Luck.
Nov 17, 2010 | Miele Novotronic Premier 500 Front Load...
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
Washing machine not spinning
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section appliance will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent ( Y - Piece) from drain pump blocked.This requires front panel to be removed.
If the machine detects a fault then an indicator light will flash,(rinse light for motor circuit).
Apr 22, 2010 | Miele Novotronic Premier 500 Front Load...
I need to change the door around on my miele premier 520 machine and have lost manuel
It is not possible to reverse door. Instruction books are available to download from Miele web site
Apr 11, 2010 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
The conditioner part of the drawer is still blocked. Take the drawer out and turn it over, on the bottom of the drawer you will see what looks like a blanking plug, it's about 1" or so in diameter. Carefully, prise off the plug with a flat blade screwdriver, and you will find lots of sludge blocking the syphon path. Remove syphon and and run hot water through until you can see daylight through the syphon hole where you just removed that blanking plug. Re-fit blanking plug giving it a little tap home. This should sort it.
Jan 07, 2008 | Miele Novotronic Premier 500 Front Load...
Miele 300 Front Load Washer Logo
908 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
