Question about IBM ThinkPad T30 2366 Notebook
Good memory modules put into second slot are not detected in T-30. The second 512 MB module does not show up in the BIOS setup or in Windows XP.
  • mcneel Feb 03, 2010
    Darkpain
    Thanks for responding. I am aware that each slot is supposed to take only a 512 MB module (even though some here have found that a 1GB module works for them). The PC2700 Crucial sodimm I purchased works fine in the first slot, as does the original module. However neither work in the second, alone or in combination. From reading this forum and others it is obvious to me now that the problem is most likely in the solder joints.
  • 316 Answers
Hello my friend,did you make sure that the ram you installed is DDR SDRAM/Non-ECC/266.0 MHz and that you did put more that 1GB RAM that is the maximum amount your motherboard can take?
Posted on Feb 03, 2010
  • marios basileiou
    marios basileiou Feb 03, 2010
    Yea if nothing is been recognized in 2nd slot looks like is corrupted somehow on the motherboard.If its solder joints it wouldn't be hard to figure out the difference comparing with the 1st slot and repair it but if its slot problem and deeper the only solution is the repair shop
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
Vram is 256 mb but dedicated is 64 mb and shared is 192mb . how do i change it.. no option in bios also. Sony vgn n220e
You should not change this. Laptops have small video chips and often depend on "shared" memory to achieve good performance without overheating. Basically, the video processor borrows some of your installed RAM memory. Also, your laptop may have been supplied to you with less total RAM memory than the maximum and you can add more memory. In Windows, click on Start then right-click on Computer and select Properties. In the Properties window you can read how much total memory is installed. 2GB (2048MB) is a desrirable amount for Windows XP. Windows Vista and Windows 7 can benefit by having total 4GB of RAM memory. Check your Sony user manual for instructions on adding more memory. Basically, you turn off the laptop, remove the battery pack and unscrew a small cover on the bottom of the laptop to access the memory slots. Usually, there are 2 slots here. Ideally, you should install a matched pair of memory modules (a "kit") for peak performance. However, quantity of memory is more important than having matched modules, so if one slot is occupied and the other slot is empty you may simply buy one more module and install it in the empty slot.
Aug 13, 2013 | Sony VAIO VGN-N220E/W Notebook
Dell Precision 530 with dual Xeon CPUs. Uses Rambus memory. (4) 256mb ECC modules are installed. It should be a total of 1 gb. However, BIOS only shows 256mb total even though it shows all 4 rambus...
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM: http://en.wikipedia.org/wiki/RDRAM
May 15, 2011 | Dell Precision 530 PC Desktop
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Acer Extensa 5620Z will not work with more than 2GB RAM??
parrotheadpc is incorrect in stating "you can only have a total of 2048 mb installed".
the 5620Z accepts 2 x 2 GB SODIMM RAM, the machine boots and shows the full 4 GB in the BIOS.
the full 4 GB works with the Ubuntu x64 installer.
Windows XP x32 goes BSOD on startup.
Windows 7 x64 install from DVD fails with same BSOD error.
conclusion: this is a Windows-Extensa 5620Z incompatibility that would require a fix by ACER at the BIOS level.
question: there may be specific memory modules 2 x 2 GB which do work--anyone have it work with Windows?
Oct 02, 2009 | Acer Extensa 5620 Notebook PC
My Dell Latitude C840 works only with one memory module
Your motherboard is bad or there might be something in the slot preventing the memory from seating properly.Check if there is something in the slot preventing the memory from seatting properly.good luck
Sep 14, 2009 | Dell Latitude C840 Notebook
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Toshiba satellite a100,wa-1 memory upgrade
Take out all the memory cards and wipe the gold part of the memory modules.
Then insert the two 512 modules & check the memory.
If it shows the correct readings, then the two modules are detected.
Then insert the 1 gb & other one 512 module.
Then use the other one gb with the same 512 & check if it shows the correct readings.
Then the two 2 gb modules are fine.
Now insert the two 1 gb modules & check now.
There are ECC type & non-ECC type memory modules are available, chck which one your computer supports & which type you have.
If it shows the correct readings, then the two modules are detected and fine.
Then you can also swap the slot and check if any memory module is not detectd correctly.
Some have four slots & i dont know how many slots your laptop have.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Toshiba Satellite A100-S8111TD Notebook
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce: http://www.memorystock.com/memory/CompaqEvoN610C.html)
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
http://www.pcfixreview.com/blog/2007/07/12/bad-pool-caller/
http://www.registrysimple.com/bad-pool-caller-fix.php
May 08, 2008 | Compaq Evo N610C Notebook
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
IBM ThinkPad T30 2366 Notebook Logo
85 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
