Question about Canon P23-DHV Calculator
I don't know how to put my paper in it. - Canon P23-DHV Calculator
    Master:
  • Canon Master
  • 406 Answers
After hanging the paper role in its position, insert the edge from behind and press feed, continue until the edge is out on the opposite side.
Posted on Feb 03, 2010
I don't know paper sensor. I search paper sensor.
small black plastic near paper feed unit or sometimes back of fixing unit and in up of cover
Feb 19, 2013 | Office Equipment & Supplies
Don't know where to put the paper
What paper are you on about? motherboards don't use paper.
Nov 28, 2012 | HEWLETT-PACKARD 5188-7535 Motherboard
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
All telephony functions, including emergeny call are disable due toa communicatio eror
Basically the solution is to claim the warranty and Nokia replaces a new one for you, what if you are out of warranty, just someone like me? Nokia has no answer for that, thank you Nokia ;)
I was thinking "Sim card icon and communication error", maybe it is sim card slot issue? I don't know, but here's what I try -
0. Switch off N9001. Open up N900 case at the back(battery part)2. Take out battery3. Take out sim card from the slot, clean it4. Put the sim card back to the slot5. Tighten the slot6. Take the toilet paper, yes I say toilet paper because it was on my desk when I was trying to fix this7. Try to tear the toilet paper and make it thicker by layering them8. Make the toilet paper slightly same size(square) as the sim card slot9. Put the toilet paper on top of the sim card slot and push in a bit10. Put back your battery and press it little hard, the toilet paper will be underneath11. Close the case12. Switch on your phone
The phone works automagically, don't ask me why, it's really high tech fix if you ever encounter this issue.
Jan 03, 2012 | Nokia N900 Smartphone
Says "error" and don't know
If the error light is flashing: Check the front door and the fuser door to be sure that they are closed. Also check for any jam including the duplex section. Make sure there is not a sensor flag stuck in the down position. This can indicate memory full, print overrun, size error DX or duplex disabled.
If the error light is not flashing: it can mean there is no paper in tray 1 or the machine may be asking for you to put paper in the multi purpose tray.
Is this the only light that is on?
Jul 06, 2011 | Brother HL2240D Laser Printer
I dont know where to put the papper in
I hope I can help!
Basically, you are going to load the paper in the very bottom tray. If you fold down the frontal tray, there should be enough space for a good stack of paper (but don't overload it!). You just put the paper in the bottom tray, and then it will feed through there and come out the tray just above it when it prints. If you need any more specific instructions, I will post a link to the HP manual on this printer. Just click on "load originals and paper" on the left, and then "load paper" and it has some good instructions with pictures. If you need any more help, just comment!
Link
I hope that helps!
Jun 17, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
Can I put ground coffee directly into the brewer basket to make a cup of coffee? I don't have a coffee pod
Nope, don't put the ground coffee directly into it. Instead try using a Napkin or Paper towel.
A piece of cloth may also be used, but the paper towel is preferable.
Hope it works out!
May 31, 2011 | Vacuums
I have a optras1855 printer and a message keeps coming up 241 paper jam check tray 1. the problem is there is no paper jam. i know this because i have another machine the same model and that does the same...
I'll bet that if you put a mark on the top sheet of paper in tray one and then send a print job or run a self test you will see that the paper stays in tray one. I suspect that you have a paper pick problem.
Worn or slick rollers can be one source or a weak tray supports. Also, take the paper out of tray one and fan the paper to break any static that may cause the paper to stick together.
Don
Dec 17, 2009 | Lexmark Optra S 1855 Laser Printer
I cann;t Copy or print in paper 81/2 x 14 in the IR 3100 canon
Just guessing.... Not knowing the model or Make of the copier. You Probably have to change the papersize on the drawer that you are putting the larger paper into to equal 8.5x14: usually by a dial or the position of the fences (side and rear paper guides inside of the tray)....
Mar 29, 2009 | Office Equipment & Supplies
Canon P23-DHV Calculator Logo
85 people viewed this question
old marine
old marine
