Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
My heater keeps getting a ee 12 code and shuts down. What do I need to do?
  • glazekenneth Feb 04, 2010
    Thanks for the info and I think the swich will need to be replaced for circulation is not the problum.
  • 767 Answers
This error code pertains to the high limit switch being tripped from overheating. Be sure that the unit is getting enough circulation from surround air this could cause the high limit to trip or the switch could be faulty powering the unit off for a few minutes and turning it back on or repowering it should reset the fault once the switch cools off.
Posted on Feb 03, 2010
My Toyo Laser 30 has an error code EE 5 and I can't find any info on that particular code. Help?
Call manufacturer or Installer - Direct Vent Furnaces are not a DIY service. Carbon Monoxide is deadly and can easily be emitted if there is something wrong with the heater. Get professional help before anything further is done, as it needs a full inspection for your safety.
Apr 14, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Stove shuts down and code ee 2 or ee6 comes up , what is my promblem.
Probably a fuel flow problem. Does the pump start making a loud thumping sound before the heater cuts off. Check the fuel filter and the strainer in the fue sump. Turn off the fuel at the barrel before removing the fuel strainer. Also check the flame sensor. Unplug the heater before attempting to remove the flame rod because it may burn out the circuit board if it touches metal with the heater plugged in. Use some steelwool or fine sandpaper to clean it if it is dirty. Another possibility with the EE-6 is that it is overheating, however, since you are getting EE-2 also I would suspect that fuel is the problem. Another thing to check would be the fuel nozzle. It can sometimes get clogged with carbon deposits. Let me know what you find if this doesn't fix it.
Dec 27, 2010 | Rinnai Toyostove Direct Vent Heater:...
Error code 12
Three main causes.
Short circuit on the low voltage side of the wiring (12V) This will show as an immeadiate error code 12 befoe the thing even tries to light.
Faulty earth on the low voltage side shows same as above.
A faulty gas regulator or partial blockage of gas supply that allows the unit to fire, but will not maintain sufficient gas supply to keep it alight. This will happen after it has lit, maybe erratically with the occasional error code 11 if you try and re-light immeadiately.
May 13, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My Laser 30 keeps getting a ee 12 code ans shuts
Ken,
The screen for the circulating fan has lint on it. Remove it from the back top panel and wipe it off. The lint keeps the air from be able to blow over the stove and it overheats.
Good luck,
Tom
Feb 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Heater keeps shuting down and displaying EE 6
Check for air leaks in the fuel line. Push the red reset button only once. It's usually a fuel problem. Contamination, air, mixed fuel.
Nov 26, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
EE 8 code on TR-73 toyostove!
If you can't get rid of the EE8 message and you think the motor is really turning it may be turning too slow. This will be caused by corrosion that has dripped down into the blower and gotten on the Rev sensor. The solution is to change the motor. If you are not handy with tools you may have to just change the whole blower. The motor is around $150, the whole blower is $350. The corrosion may have happened over the summer and fall.Heating and cooling causes condensation and the water drips down into the blower.
Tom Hawkins
hawkins111@gci.net
Feb 25, 2009 | Rinnai Toyostove Direct Vent Heater:...
My Heater shuts down and I don't have a manuual to trouble shoot it.
I NEED TO KNOW WHAT THE EE2 CODE MEANS.ON YOUR FURNACE THERE IS A LIST OF ERROR CODES,PROBABLY ON THE BACK OF THE DOOR ON THE HEATER.WE NEED TO START FROM THERE TO GET AN UNDERSTANDING OF WHAT THE UNIT IS TRYING TO TELL US. JEFF
Dec 15, 2007 | Heating & Cooling
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
46 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
