Question about GE Refrigerators
GE Refrigerator GSS25IFPA WW makes ice but will not dispense cold water.
  • 1 more comment
  • gclelvis Feb 03, 2010
    Cannot hear a solenoid start-up.
    Where do I look for the solenoid power connection? In the door or in the back of the freezer compartment.?
    Could not hear the solenoid power on.
    Where do I find the power connection to the solenoid? In the door or in the rear of the freezer compartment?
    I commented on a proposed solution an hour ago and have not received a second reply to my problem.
    Here is the problem again:
    GE refrigerator Model GSS25IFPA WW will not dispense cold water although it will dispense ice thru the door.
    I do not hear the solenoid come on when I press the cold water switch. I was told then to see if the solenoid was getting power.
    Do not know where to look for the solenoid. Is it located in the door? In the freezer?
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Posted on Feb 03, 2010
    President:
  • 2,468 Answers
Can you hear the water solenoid valve actuate and hum when the switch is depressed for water,if not the solenoid either isn't getting power to it to actuate or its defective,or you could have a blockage in the line(not very likely though)
I have a GE GSH22JFTA WW that will not dispense water. Does dispense ice, crushed and cube. Panel is not locked. What part do I need? Thanks!
in the back of the fridge there is a module with the solonoid on it to open and close for the water, and it usually get damaged because of hard water, it is about 15.00
Aug 29, 2014 | Refrigerators
GE refrigerator/model GSS201EPH WW. Water dispenser works fine, ice dispenser does not work
there is a pump which pushes water up to ice maker, it usually quits, causes the prob. 90% time
Jul 17, 2011 | GE Refrigerators
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
