Question about Westinghouse TX-52F480S 52 in. LCD TV
No picture. Led is amber for off, blue for on. Unplugged, then replugged and pressed on button. Westinghouse symbol shows on screen, no picture. Led is amber and never turns blue. Repeat and same problem.
  • gibacosta Feb 05, 2010
    Thanks for the assist. Found out my Westinghouse is covered for two years by Costco. I just need to call and schedule service. Hopefully they can fix the problem. I will post their findings.
  • John Sia
    John Sia Sep 19, 2011
    I got the same exact problem. did the tech told you what was the problem? My TV is out of warranty....
    thanks
  • 4,889 Answers
Since the Westinghouse symbol shows up on screen, it means that is is unlikely to be a backlight or inverter related issue.. More so since the light stays amber. Did you check the power supply board for any obvious looking faults like swollen at the top/cracked/leaky caps or the 1.5A fuse?
Posted on Feb 03, 2010
  • eagle338
    eagle338 Feb 05, 2010
    That is cool! Yes please do post their findings.
    Sai.
I have a Westinghouse WD55UT4490 TW-04401-L055A 55" LED that I can't get to turn back on.
Try the flashlight test and see if you can see an image on the screen that way...do you have sound? If you dont have either then chances are its the power board, however sets made by Funai are known for LED lamp failure in the panel
Mar 13, 2018 | Westinghouse Televison & Video
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
Oct 25, 2017 | Westinghouse Televison & Video
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Westinghouse 42" 1080i won't power on.
PSU CHECK FUSE /CAPACITOR/FET
Nov 14, 2013 | Televison & Video
My memory card shows 132 pictures are loaded, but when I put the card in the photoframe, it keeps showing only 4 pictures. I have unplugged and replugged the photframe - but still just the same 4 pictures...
It is possible that they are in a format the picture frame doesnt support. Browse the card with your PC, find the pictures the frame will display and make sure all the other pictures are the same format (ie. jpg, gif, bmp etc).
Jul 24, 2009 | Westinghouse 7" LCD Digital Photo Frame
Westinghouse TX-52F480S 52 in. LCD TV Logo
226 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
