Question about True (TSSU278ADA)
Need manual for true tssu 27 8 - True (TSSU278ADA)
  • True Master
  • 1,250 Answers
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Jul 22, 2016 | True TSSU-60-16-ADA Stainless Steel...
I got a true tssu-27 that won't cool what would be the problem with this unit?
Many times the air circulation across the condenser is the problem. Take a look at the condenser and make sure that the condenser fan is running and there isn't dirt or grease blocking air movement. There is also the obvious like a compressor that's not running or an iced up cooling coil. Is the compressor hot? Maybe an additional description would help. Are the fans inside the cabinet running? Good luck hope this helps.
Oct 23, 2014 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Unit freezing up
as a former cook
do not line the bottom with foil
and clean the vents in the back
Oct 03, 2009 | True Sandwich Unit - TSSU-27-12M-C
Water leaking into fridge
Open the back of the unit. There you will see a drain line. Use something to blow through it and clear blockage. If the drain is clear the drain pan may be rusted through. :)
Jun 05, 2009 | True TSSU-27-12M Refrigerator Commercial
Refrigerator keeps freezing up
check the door gaskets on the unit they could be leetting in too much moisture and that will cause the unit to form too much ice,
Mar 26, 2009 | True TSSU-27-12M-B Commercial Refrigerator
True (TSSU278ADA) Logo
180 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
