Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
I have an old bunn-0-matic, model x-15,s#18871, when I pour water in the top, water comes out the fitting on top of the resevoir that has the wire going down into it.
    President:
  • 1,618 Answers
Sounds like you need a new grommet for the machine.
Posted on Feb 03, 2010
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
I pour water into my Bunn BX10 and it starts running out the bottom -- what is causing this.
It sounds like your brewer has a bad seal/gasket. Please get the model and code date located on the bottom of the unit and contact customer service. The brewer has a 3 year warranty and if your machine is 3 years old or less it will be replaced free of charge. If it is over 3 years old, it will be replaced at a reduced price.
Jun 06, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
Mar 19, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Leaking pour basin
Your only hope of getting a new tray for these would be if your local Bunn repair shop has some hanging around that broke down for another reason. This is a very common problem with those models. You can find a list of Bunn repair depots at www.bunn.com Good luck!
Jan 21, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
RANCID BUTTER melted in Bunn Thermofresh resevoir vents!
There is one thing you can try first. With the machine filled with water and turned on, pour in 1 quart of white vinegar and let it sit in there for 2 hours. Then flush it back out with 8-10 carafes of water. If this doesn't correct the problem, then call customer service with the model and code date. This can be replaced under the warranty if it is under 3 years old or less. If it is over 3 years old, it can be replaced at a reduced price.
Jan 12, 2009 | Bunn NHB Coffee Maker
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Coffee Brewer comes out warm not hot
look at the top of the coffee maker you'll see two screws and the warmer tray and the cover for adding water. remove the two screws and lift the top off. the warmer has two push on spade terminals. pull the wires off them. below is a tray where the water goes and you'll see a brass bushing. this is screwed into a fitting on the water tank. use a piece of steel as a spanner and unscrew this fitting. don't lose the gasket that's under it. the main wires for the burner element and thermostat are also under this tray. look at the top. there's nine screws that hold the top on the water tank. two white wires go to the tank warmer and two wires go to the tank heater inside. you can try turning up the thermostat setting to a higher range and see what happens. there's a copper pipe that comes from the tank to the sprayhead the tank holds approx three urn fulls of water. if you have an analog meter you can check the element for continuity on the RX1 range. Do the same with the tank warmer element. Bunn-o-matic has a web site you can buy replacement parts or nelson appliance can get you parts too.
Nov 19, 2007 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
158 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
