Question about HP OfficeJet r40 InkJet Printer
Can't get print heads to align and the printer
Can't get print heads to align and so the quality of print outs is terrible. Also, the printer makes very loud jerky movements when printing. How can I fix this?
SOURCE: Printer cartridge alignment
Pressing "setup" and "options" together works for me.
Posted on Aug 07, 2007
  • 141 Answers
SOURCE: print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Posted on Oct 02, 2008
  • 14 Answers
SOURCE: Epson Artison 800 Poor Print Quality
it sounds like you have clogged the head if you leave it for 6 hours then the ink will dry inside the head then you have a big prob if i were you i would take it back to the shop and get a refund or a replacement one i have an epson dx4400 very good
Posted on Mar 21, 2009
Tinteiros
  • 85 Answers
SOURCE: Canon i850 printer is printing striped colors
HTML clipboardIf you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time?
Then provided it worked OK before a period of non-use? You just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
A Magic Inkjet Flush Kit usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Posted on Mar 22, 2009
SOURCE: black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Posted on Jun 11, 2009
I am getting an error telling me to replace all 4 print heads. I thought it was odd that all 4 would go out at the same time. Should i replace all 4 print heads or is the problem something else? Maybe
This is general problem in hp plotters..
understand the concept: If U R replaced any one of print head in good working printer, printer detects new print head & it will try to align it with others. Printer will print align page to read, while reading if its found any other print heads are poor quality or bad condition, it will say to replace them also.. Some times it may 2,3 or all.
If UR printer is trying to printing align page and reading it, definitely it will detects & displays the faulty /poor quality print heads. U have to replace it..
If UR feels its expensive, try to clean the print heads manually & try for UR luck...
Trailing cable error is 11:11...
Mar 24, 2014 | HP DesignJet 500 InkJet Printer
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My Kodak 3250 printer is printing very faded. I've changed the ink cartridges, even taken out the print head itself and cleaned it with alcohol. Calibrated it several times, print head aligned it several...
First if you used ALCOHOL on the print heads you most certainly made some DAMAGE because alcohol will MELT the microscopic electronic nozels, the best way to clean a jet ink head is to soak it into WARM WATER NOT ALCOHOL, if your lucky you could try soaking the head in warm water for 30 minuts, than VERY DELYCATELY dry it with a scott towel, than use GENUINE KODAK INK not generic or re-filled ink cartridges if all that does not work, well you probably need a new print head
Jan 12, 2011 | Computers & Internet
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
Good Luck!
Tinteiros (Ebay)
Mar 17, 2009 | Canon i850 InkJet Photo Printer
My printer makes lines through all the pictures i try to print
Make sure your quality options is set for best photo, also change paper to glossy photo paper. Under the maintenance button try to clean the print head and then try a print head alignment. I hope this helps you........Hutch
Dec 20, 2008 | Epson Stylus CX3810 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
If reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Step four: Clean the printheads
If the print quality is still bad, clean the printheads.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
Open the printer Toolbox and select the Printer Services tab.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads
If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
Press the Setup button.
Press 1 and * simultaneously.
Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
If the Black block has lines – replace the KY printhead.
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
If the Red block has lines – replace the KY printhead.
If the Green block has lines – replace the KY printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Bad colors in print
perfrom a deep head clean 2 times this will clean the printer printer head out. make sure u have heaps of in in your ink tanks as it uses a bit of ink to clean the heads out. then try and do a print. also you may need to do a head alignment on the printer. this head alignment should be done after u replace ink tanks.
the only other item it could be is the print head on the printer.
Nov 20, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP OfficeJet r40 InkJet Printer Logo
Seeker5211
Seeker5211
