Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
LCD display works while in record mode but the touch screen commands quit working altogether. Wondering if there is any do it yourself solution.
  • nparks709 Feb 03, 2010
    Sounds good, what is the part number, and do you know approximately what it should cost?
    Thanks,
  • 10,594 Answers
If it is Sony DCR-HC21 camcorder then it is touch screen problem and you need to replace LCD Screen as it has touch buttons pad.
LCD screen replacement is easy, 4 screws to take off LCD cabinet cover, 2 more screws inside to take out LCD screen, few connectors to unplug flexible ribbon wires.
Let me know if you want to replace LCD Screen by yourself to provide you part number info.
Thanks.
Posted on Feb 03, 2010
  • Shahid Electronics
    Shahid Electronics Feb 03, 2010
    Thanks,
    A1090679A.... (TP) BLOCK ASSY (2.5STFU) (HC17E/HC19E/HC21E/HC22E)
    Above is LCD screen part number, seems not available.
    Please call Sony Parts Store on 1-800-538-7550 for information.
    I forgot to mention, there are 2 type of LCD Screen have been utilized in DCR-HC21 camcorder,
    1- (2.5STMG)
    A1090680A (TP) BLOCK ASSY (2.5STMG) (HC21/HC32/HC32E/HC33/HC33E)
    2- (2.5STFU)
    Please confirm LCD part number accordingly.
Garmin Nuvi 1300 touch screen not working
It sounds like you need your touchscreen replaced. The touchscreen is soldered to the LCD display, so the touchscreen must be unsoldered from the LCD display and a new touchscreen resoldered to the LCD display. Please do not attempt to do this yourself. You can easily damage the LCD display in the process. More information about touchscreen replacement can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Apr 21, 2013 | Garmin nuvi GPS
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
Touch screen is broken
It sounds like the LCD is broken. The Touch screen digitizer and the LCD are two seperate components, the LCD is the visual part that shows the display and the digitzer is the part that you touch. You can find these parts online and attempt the repair yourself or bring it to a mobile phone repair centre for a professional job.
May 28, 2009 | LG KU990 Viewty
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Command mode change
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Jan 04, 2009 | Sony RDR-VX521 DVD Recorder/VCR
LCD touch screen will not work
Connecting flexible ribbon cable between LCD board and Camera main board is cracked on some points and needs to be replaced.
if you have experience of camera repair, let me know to help you further or take camera to tech person for proper fix.
Dec 23, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Sep 14, 2005 | Sony DXC-190 Camcorder
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
191 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
