Question about Texas Instruments TI-83 Plus Calculator
Only the on button and shade of screen works
Ive tried turning on and off my calculator, which works just fine, you can see the screen turn on, yet it is blank. i tried changing the shade of the screen, which also works, but no other buttons work, ive cant see anything at all. this happened, so i took out the batteries and put them back in, it gave me a screen with a bunch or random dots and a couple values, but the numbers were incomplete. i took out the batteries once more, and it went back to the blank screen. does this mean theres something wrong with the hardware
..the batteries are quite cold, and my calculator was in the bottom of my backpack the whole way home..
  • Hillary3 Feb 21, 2008
    When I turn my calculator on I get a funny symbol in the top right corner and it doesn't go away no matter what I do. I've pressed 2nd and quit, I've hit clear, I've taken the batteries out for 15 minutes (including the lithium one). I've held the clear button and taken one of the triple A batteries out... I've never installed my calculator on the computer nor do I have a USB cable for it... the RAM cleared will come up randomly every once in a while and sometimes the calculator won't turn on at all and I will get a screen full of random pixles. I don't know what to do. HELP.
Welll what i recommend you to do is to open your call culator
this will help it fix any problems that it has
Also clean all the ends of your calculator and check all the circuits
now this will only help you if you do a slow and patient proces otherwise you will mestup your calculator
Posted on Mar 07, 2008
    Problem Solver:
  • 8 Answers
Sorry to hear that you all are having problems with your calculators. I don't think that resetting the units will help. You should contact TI.
Contact information for Texas Instruments can be found at the website below:
http://education.ti.com/educationportal/sites/US/nonProductSingle/support_contact.html
Posted on Mar 04, 2008
How to turn off shading when graphing inequalities.
The solution set of a linear inequality in two variables (x,y) is one half of the Cartesian plane. The half-plane may or may not contain the boundary line defined by the = sign. Thus it is expected that the calculator shades the relevant half-plane. If you are dealing with nonlinear inequalities the calculator shades inside or outside the curve.
When drawing multiple inequalities the Casio offers you the possibility to shade the regions where ALL conditions (ALL inequalities) are simultaneously satisfied. The other option is OR.
If you are not interested in the shading do not draw inequalities, draw equations (with =).
Aug 23, 2013 | Casio FX9750GII Graphic Calculator
Calculator turns on, but cannot turn off and no other buttons work.
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Aug 28, 2012 | Texas Instruments TI-84 Plus Calculator
Ti-83 plus silver edition, battery drain, ive
The Texas Instruments TI-83 is a graphing calculator. It's aimed towards math and science students and lets them graph and compare functions, perform data plotting and perform analysis. It has an updateable memory for adding software applications. The device comes pre-loaded with applications too. An optional connectivity kit allows you to hook the device up to your computer, and there are also optional slide cases to protect it.
  • Turn on the TI-83. Press the On button.
  • Step 2Adjust the display contrast. Press and release the key marked "2nd" and then press and hold the arrow buttons, which are below and above the yellow half-shaded circle.
  • Step 3Go to the Home Screen. You can do this from anywhere. Just press the button marked 2nd and then Quit.
  • Step 4Perform a sample calculation to get the hang of how to use the device: Model flipping a coin 10 times. Track how many of those coin flips end up in a heads result and you want to do this simulation ten times. Press Math and the left arrow which will bring up the MATH PRB menu.
  • Aug 02, 2010 | Texas Instruments TI-83 Plus Calculator
    My Ti-nspire won't turn on. Replaced batteries
    Same thing happened to me. I replaced the batteries, and now it won't progress past the start-up loading screen. It just loads and freezes. I had to remove the batteries just to turn it off.
    Jan 26, 2010 | Texas Instruments TI-Nspire Graphic...
    Computer monitor screen stays black
    please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
    Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
    19" aoc lcd monitor flashes pink constantly and turns black
    THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
    Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
    Only the on/off button works
    If it is a screen with a pattern of dots then it might be in a graphing mode with a grid showing, does pressing 2nd quit do anything? Have you tried removing the batteries and the lithium battery and then putting them back in, let me know the outcome of these trials and I will try to figure this out for you
    Mar 17, 2008 | Texas Instruments TI-83 Plus Calculator
    Caculator Trouble
    Try taking out ALL batteries (including the little round one) and leave them out one whole night.
    Oct 31, 2007 | Texas Instruments TI-84 Plus Calculator
    Texas Instruments TI-83 Plus Calculator Logo
    149 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
