Question about Motorola Mobility RAZR V3
Invalid Battery I woke up and couldn't open up menu but the only thing I could do is dial out and receive calls. I turned my phone off and back on and got a message that said invalid battery. And when I plug in my phone charger I get the same message.
  • Anonymous Mar 03, 2008
    I've Motorola RAZR V9 keep saying invalid battery for no reason, i got this phone two months ago..
  • Anonymous May 28, 2008
    motorola razr2 v9, had multiple battery issues, have only had the phone for 6 days, says invalid battery for no good reason, plus battery goes flat after a full charge within 3-8 hours,rubbish battery charging issues.
Try open up battery, put it back in & plug in charger again.. wait for a bit then turn phone back on. Hope this helps!
Posted on Feb 20, 2008
Keep getting dial tone on my phone, unable to receive or send calls
Step 1:
try turning off the phone taking the battery out for 15 seconds then re inserting it and turn the phone back on
Step 2:
if that does not work then try to factory reset it
Step 3:
then if that does not work take it to the store and ask them to troubleshoot it
Dec 11, 2012 | HTC Cell Phones
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
Can't receive calls on my ZTE warp
somthing wrong with your settings.
restart your cellphone,
Jan 18, 2012 | ZTE Warp
I purchased an extra handset to a AT&T uniden E2125 system. The phone instructs me to place new handset on main base to register handset. It has registered and now it reads, handset #5. When I try...
I've pulled up the user manual for your phone. Thank you for providing the phone make and model first, and the complete description of your issue!
The manual says the battery should be charged for 15 hours before first use.
You may be set to pulse dialing , even though the factory default is for tone dialing. If you push the 7 key, you would hear 7 pulses or clicks in succession. The dial tone will be gone once a pulse has been received. And you say there are clicks heard and no dial tone.
You can set Handset settings (Page 12 in the PDF copy) and customize how your phone works.
Hit MENU and use the up-arrow and down-arrow keys to scroll to the desired feature., this time called DIAL TYPE, then his SELECT. Looks like the sixth menu entry from the top after LANGUAGE.
It should read:
DIAL TYPE
TONE
If it says something else, perhaps PULSE, use those arrow keys again to change the Dial Type to Tone. Then use OFF to back out of the selection and again to clear the menu.
Attached is the link to the manual. Click the button on the screen to "Open as PDF" and you can open it in your PDF reader software or save it to your device for offline reading.
http://phone.manualsonline.com/manuals/mfg/att/e2125.html
Jan 07, 2018 | AT&T E2125 (650530003738) Cordless Phone
My samsung instinct is stuck on dial pad,i cant acess any other menu but my speed dial and dial pad.cant dial any number cos if i try to dial one it shows im pushing nine instead.
do what is called a "hard reset". take the battery out while the phone is still on and leave it sit for about a minute, then return the battery to the phone and turn it on. see if this helps. if not, back up your phone and try doing a full reset.
Jul 11, 2009 | Samsung Instinct Cell Phone
Can take and make calls but details don't show on my E90
I'm sure you have already tried this, but have you taken the battery out and put it back in again?
If it's still hung, then you can try doing a reset on the PDA section, but this will erase all your data, so be sure that you have it backed up.
Start by doing the phone reset - dial *#7370# from the phone keypad and then enter the security code (which will be 12345 if you have never changed it) - if that doesn't work, then reformat the filesystem in the PDA:
Take the battery out, hold down "*", "3" and the "Green phone" button and while holding them down put the battery back in - wait until it asks you if you want to reformat. Again, this will erase all your data and settings (and also any of the factory pre-installed content in the internal memory).
Jul 01, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Touch pad is not working; can't do anything but receive calls-
Please reset your phone by removing the battery from the back for 5mins.Connect the phone to the power cord and then reinsert the battery again.Then press and hold the power button for 1 min.This should fix the issue.If you still face any problems then you will have to get it repaired.I hope your Phone is under warranty.
May 15, 2009 | Samsung SGH-U600 Cellular Phone
Possesed phone
Sounds like some sort of short in you keypad, possibly some water or liquid has come in contact with your phone?
You should seek service IMO.
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Missed calls
How do I view the numbers of calls made or received? space.gif space.gif answer.gif You can view the last ten calls that have been placed and the last ten calls which have been received in the Recent Calls option menu.
  • Press the Menu, Recent Calls and press the right soft key to select.
  • To view the calls you have received scroll to Received Calls and press the right soft key to select.
  • To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
  • Once in the Received or Dialed calls you can get more information such as the time the phone call was received/dialed by highlighting the call you want to view, and press the right soft key to view.
  • Scroll down to view all the available information.
In order to delete a received, or dialed call simply highlight the call you want to delete, press Menu and then select Delete. You can delete all the calls in the chosen section by selecting Delete All instead of just delete.
Mar 13, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
486 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
