Question about Nokia 6133 Cellular Phone
BATTERY DIES QUICKLY LAST ABOUT 12 HOURS AT MOST BATTERY NEW AND PHONE HAS BEED RESET
  • 182 Answers
Swtich of your phone first recharge your battery continously for upto 6 hours only use nokia original charger and battery . and use the phone .... thats all
Posted on Feb 03, 2010
My phone gets hot and won't stay charged for more than 4 hours and then dies without being used.
How long have you had it? That sounds like a warranty issue. Unfortunately there really isn't anything you can do to fix that. Probably needs a new battery.
Dec 11, 2016 | ZTE Cell Phones
Battery dies too quickly
Did you fully charge your battery when you first opened the phone? If not, the battery will never hold a full charge. it tells in the booklet that comes with your phone. Not giving your phone at least 16 hours on the first charge might cause battery trouble later. You may need to replace the battery. I hope this helps.
Mar 21, 2012 | Samsung Behold Cell Phone
My cell phone battery dies much quickly
Some cell phone batteries work fine for a short period of time and then rapidly diminish their holding capacity. The battery that has previously worked fine for 10 days standby begins a downward time drop to last merely a couple of days. A simple procedure that I have found to be invaluable is to:
1. Turn the power to the phone off.
2. Remove the battery from the phone.
3. Replace the battery into the phone.
4. Fully charge the battery.
5. Test the results by noting the time and day of item 4 above. Leave the phone on standby and see if the charge will now last many days. If so, congratulations, your phone is almost as good as new, and you didn't need to find and buy a new battery (or bother the customer service staff).
Feb 05, 2012 | Sharp Cell Phones
Mt bettery goes down quickly
You may need to replace your battery. It sounds like it may be going bad.
Before you do, plug your phone in for at least 12 hours to charge it fully. If it continues to go down quickly, you may wish to try another (New) battery.
Jan 24, 2011 | Cell Phones
Battery dies within 24 hours
Hi, what makes the phone battery to die to quickly, is because the battery cell to weak and almost damaged completely and it's unable to power the phone for too long.
The battery cell is damaged.So you will need to replace the battery with a new battery.
You can go to any phone store around your area and get a new battery to replace the old battery.
When a new battery is is purchased, usually comes with a factory battery life whic is not yet fully charged.You will need to charge the battery for longer hour before use.
After purchasing a new battery, make sure you take time out to charge the battery properly for about 4 to 6 hour before use,otherwise battery cell can go flat again in no time.
Hope that helped.
Thanks for using fixya...
Jan 16, 2011 | Samsung Convoy Cell Phone
Battery goes flat very quickly
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the backlight will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone. If you have not tried to buy a new battery yet, the ones that come with the phone can often ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway.
Oct 02, 2009 | LG KU990 Viewty
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
The battery on my brand new missil MP4 only last 20 minutes
Hi There,                Make sure you fully charge the device for 4 hours. On the setting on your device you should have a screen saver to shut off the screen display in a few second. Set this to saver battery time and set the auto off function if not in use for a long while to save more battery time. If your display screen stays on all the time that is the reason your battery dies so fast. Also playing your music loud for long period of time can drain the battery fast too.
Dec 29, 2008 | Network Computing Devices (NSH800S/A)...
Battery Dies
Part number 23-270 at your local radioshack. Sells for 14.99. Good luck. And make sure you charge the new battery for 8-12 hours.
Sep 14, 2007 | Panasonic KX TG2570 Cordless Phone
Phone dies quickly after charging
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but... Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever). Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies. If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current. This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different. Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities. A.
Jul 25, 2007 | Motorola Mobility RAZR V3
Nokia 6133 Cellular Phone Logo
65 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
