Question about Microsoft Xbox Console
Hi when i turn on the xbox they power light on xbox comes on for 1 secend and gose off and the power box is yellow then green then red and back to yellow in a few secends i have try an other power lead but the xbox wont turn on it has being working ok
    Genius:
  • 1,234 Answers
Hi Sir
ITs the three red dots of death , what i mean is they had that all over and had millions of people had to recall them, i guess your just getting crapy xbox's my friends xbox did that, he took to a shop to get it fixed, but they couldnt, so i guess your sol, get xbox 360 elite they hardly had any problems with those.
Welcome
Posted on Aug 27, 2010
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
When you turn it on it gose green and than mach turns off and power box turns red
there is a short in the power brick(box) you will need to replace it. the cheapest place is ebay or amazon but there are a number of places. Try not to pay 25 new for the power brick.
Aug 15, 2011 | Microsoft Xbox 360 Console
The problem with our X-box is that when you turn on, a flashing red light comes on
1 red light hardware fail or minior problem 2 is for over heating 3 is death and 4 etc call microsoft at 1-800-4my-xbox befor this cheack all cables and make sure you power brick is not yellow or red it should be green when on or orange when in standby
Dec 05, 2010 | SNK Xbox 360 Arcade Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Tree lights in red
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Battery Pack or Ac Adapter
check the light on the box. if it has no light no power is getting to the box. if its red then it could be a xbox problem. yellow is standby and green the xbox is turned on.
Sep 15, 2008 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
Xbox shuts off
It may actually be that your power box has failed or died. If so than you cant do anything really.Sorry.
Feb 10, 2008 | Microsoft Xbox 360 Console
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
