Question about Brother MFC-9420CN All-In-One Laser Printer
Faded spot on one side?
This printer hasn't had all that much use but when you print something, especially in color the left hand side has an uneven section about an inch or more wide that prints in a very faded orange color. You can still recognize what it is, but it looks just horrible. Any suggestion on what we might need to clean or replace to repair this?
Clean toner drum and if problem not solve so clean also fuser and scanner assy.
Posted on Feb 25, 2008
Brother mfc 7345n left side of printing and scanning and copying very light
Clean the inside of the printer especially the internal top part , if the toner is inside, pls clean and wipe the inside. this can cause light and uneven print out.
Jan 19, 2011 | Brother Imprimante MFC7225N AllInOne Laser...
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
Printer making marks down the left hand side of every page
hello,
This sounds like the photoconductor units for both black and blue need to e replaced. Open the front of the printer like you are changing toner cartridges. On the front door parts that opens to you there will e four pieces, 1 for each color. Look at the one with blue on it and the one with black and look on the ends of these, they are the photoconductor units. I bet both of the colors have worn sections compared tothe magenta and yellow ones. The replacement part number is C53030X and you will need 2 of these. They have a life span just like toner and have to be replaced too.
I hope this helps,
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | Lexmark E232 Laser Printer
Double printing, especially down the left hand side of page
replace fuser,if still happening replace transfer belt
Apr 30, 2009 | HP Color LaserJet 2600n Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Faded print on left hand side of paper
This type of printing defect is normally caused by 1 of a few problems - the easier one first:
1. Toner cartridges sometimes do not have the toner evenly distributed - close the toner cartridge and inspect the hopper right below it for even distribution of toner.
The harder ones:
2. This type of defect can also be caused by dirty charging section - for the drum to pick up the toner it must be charged electrically prior to exposure - if the charge grid is not clean then it will not give the drum an even charge - not sure were this is in this printer yet - looks like it comes as part of the drum kit so this should not be causing this issue.
3. The last and most difficult to check is paper alignment with the drum - is the paper contacting the drum evenly - look for possible problems in the paper path with the drum unit removed - look for something uneven around the area were the paper contacts the drum
Mar 27, 2008 | OKI B4350 Laser Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
How can I get A4 size borderless prints
From what I can see, this printer can only do borderless prints onto 4x6" paper only. Larger print jobs such as your A4 will have a border.
artifixit
Dec 19, 2007 | HP PSC 1410v All-in-One Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
490 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
