Question about X-10 Memphis 15-PRC41 Power Reference 4" x 10" Co-Axial Speaker Car Speaker
My speaker stop workin and the amp is fine and everything is hooked up right
  • 435 Answers
Looks like the speaker is blown , or the wiring inside the speaker is broken. To test if the speaker is working, simply hook up the terminals to the ends of a AA, AAA or C battery. Speaker should make a noise, and the cone should push outwards ( or pull inwards, if the polarity of the battery is reversed). Also test the wires that are hooked to the amplifier with a speaker that you know is good working order, just to make sure that there is nothing wrong on the wiring, on that particular channel in the amp.
Posted on Feb 19, 2010
How do i get this amp to workin an Oldsmobile Intrigue with a factory radio?
you need a hi-lo adapter and that hooks up to the right or left rear speaker then the remote wire needs to go behind the deck to the ignition wire. if the system is pre amp then you have to bypass the amp system
Aug 03, 2010 | Kenwood KAC-5201 Car Audio Amplifier
I have my vsx-1018ah receiver hooked up in for 7.1. Everything was fine for months. Now the back right speaker won't work. Speaker is fine, connection is good. Tried hooking up a different speaker and...
Assuming you're using the Surround Back speakers for their primary purpose, let's establish that there is something in the way of programming being routed to that speaker. Fire up the speaker level setup procedure and use any handy audio device (*) to see if a signal is present at the Surround Back Pre Out jack. If not, that speaker will never, uh, speak.
* For this test you could use your powered subwoofer. You DO have one, right? Just swap the RCA cable from Sub W Pre Out to the SB R Pre Out jack to see if anything appears there.
Jan 28, 2010 | Pioneer VSX-1018AH-K Receiver
I have a nitro 1200 watt amp earlier today it was workin with no problems we parked then came back in the car 3 hours later and it wasnt workin wont come on or anything just red light which is protecting...
Check your speaker wires, make sure everythings connected right with no short circuits, and check all of the fuses in the amp, and make sure none of them are blown. If all this checks out just check the battery wire, grnd, and remote wires. It has to be a wiring issue unless you busted your amp, but if was working when you tuned it off it should be alright... hop this helps...
Sep 10, 2009 | Nitro BMW-484 Car Amp
Problem with subs and amp
I would first suggest un-hooking the subs, and hooking them up to another known good radio other than the one its hooked to now. Just to make sure you didnt blow the speakers. What is the wattage of the subs? Then if the speakers do work I would hook them up bypassing the amp just to see if the problem exist before or after. Come back after doing this. Thanks
Jul 05, 2009 | Car Audio & Video
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
Speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Sep 03, 2007 | Pioneer DEH-P690UB CD Player
My amp is only pushing the left.
Swap the RCA inputs to see if the dead channel follows the RCA input.
Apr 19, 2007 | Kenwood KAC-7202 Car Audio Amplifier
My amp light is on but no sound from speaker
If the amp light is one and the protector light wasent on then I bet you blew your speaker??? take an ohm meter, measure each speaker with nit disconnected from the amp.. If they all measure what there suppose to( like 4 to 8 ohms) then the amp blew out and unless you have training on solid state electronic repair, you should seek a pro to fix the amp for ya.. Good Luck
Jun 28, 2006 | MTX 6001 Car Audio Amplifier
Car Audio & Video Logo
77 people viewed this question
Top X-10 Car Audio & Video Experts
xxxxxx xxx
Are you a X-10 Car Audio and Video Expert? Answer questions, earn points and help others
