Question about Refrigerators
Our icemaker just stopped working, we had some well problems and I woundered if someting could be plugged. The water would kick and off in the house for a week before we ended up putting down a new pump. I pulled up the icemaker arm up to shut it off shortly after the problem started but it hasnt made ice since.
  • Refrigerators Master
  • 8,220 Answers
Put some water in the ice mold and see if it kicks a batch out. If it does then you might need to check the water filter or the valve could have something in it.
Posted on Feb 03, 2010
Icemaker is in the freezer below refrigerator. stopped making ice. can hear it trying to cycle but no ice. HELP
If ice maker is running complete cycle but not filling with water you may have a bad inlet valve which is located on the back of the refrigerator. It will be the plastic part the house water line connects to. Another possibility is that the house line got blocked somehow. 3rd possibility, is if the icemaker is already full of ice and not dispensing the cubes out of the icemaker. This may be caused by the icemaker itself. There is a heater imbedded in the bottom of the icemaker that comes on and releases the cubes when it is time to dump them. That heater could be bad. That's 3 things to check.
Apr 16, 2015 | Refrigerators
Bought house with frig in it not used for a while fridge works fine turned on water for ice maker water works does't make ice
Is icemaker switch and light on? If so check for plugged fill tube. If not, the water valve or icemaker will need replacing.
Sep 25, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
The icemaker doesn't work
how long has it been out of action,( i mean switched off ), It could well be that the pump to the ice maker may now have siezed, also take a look at the filter, any sediment would now have solidified.
May 15, 2010 | Kenmore 73503 Stainless Steel Bottom...
Icemaker stops. lever to shut off icemaker frozen in place. used hair dryer to melt frozen gears and loosen lever, but water gets into gear housing again and freezes lever again
These icemakers are not repairiable.
The icemaker will need to be replaced with LG part#
AEQ36756901
This is an updated icemaker to correct the problems of past units.
Jan 17, 2010 | LG LFX25960 Bottom Freezer French Door...
I have a Kitchenaid Side By Side model KSR25FKWH05. The ice maker is not working, but the water still comes out of the water dispensor on the door. I did have the water to the entire house off last weekend...
check to see if there is ice in the icemaker, if not, put a small amount of water, like 6 ounces in it with a glass. if it kicks out some cubes, you have a bad watervalve.
Nov 01, 2009 | Refrigerators
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker has stopped working. It was fine 3 days
check water valve or icemaker valve is at the back of the unit
Apr 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
