Question about Heatrunner 33553 Heater
Heatrunner 33553 doesn't work
When I press the power button the heater beeps once, the display lights up for a split second and then dims until it is dark, then it beeps once again. nothing else.
I had tried unplugging the unit for a few minutes but that didn't work, so I unplugged it for a few hours and it re-set to a working condition.
Posted on Feb 04, 2010
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
The usb cable on my ps3 is not working will not play on any tv in house it plays with hdmi cables
Playstation 3's will not output display information via usb, it does although have a traditional Playstation style connector port for displaying via component cable/ AV cable. To switch to this display setting without having access to an HDMI television press and hold the power button until the PS3 beeps for a second time. Pressing once it will beep but continue holding until the device beeps again and it will boot into a display "safe mode" and ask you to verify your display settings.
Oct 11, 2014 | Sony Playstation 3 (PS3) Console
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Jan 24, 2011 | Tissot T-Touch T33759851
I can hear my Ps3's Sound, when the HDMI cables are connected, and it's on the correct HDMI channel, though i can't see anything, the screen is just black. I have tried holding the power down, until i...
Ok, you are actually holding the power button down for too long. Please do the following to sort out the display on your PS3.
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again about 5 seconds later. Release the power button when you hear the second beep. The display will now reset and it should detect your HDMI display with no problem.
Hope this helps
Dec 23, 2010 | Video Game Consoles & Games
No picture on tv .
Please try the following steps :-
Turn your PS3 off into standby mode (red light on)
Press and hold the power button. It will beep once when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep.
Wait for the PS3 display to reset.
Hope this helps
Oct 27, 2010 | Sony Playstation 3 (PS3) Console
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Jun 04, 2009 | Tissot T-Touch T33759851
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Heatrunner 33553 Heater Logo
183 people viewed this question
Top Heatrunner Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Heatrunner Heating and Cooling Expert? Answer questions, earn points and help others
