Question about Husqvarna Garden
350 chainsaw will not start and run, getting fuel
Husqvarna 350 chainsaw will not start and run, getting fuel and spark
Check set screws on the side of carb turn the all the way in the turn out till idles or check the screen in the muffler
Posted on Feb 04, 2010
Fuel/oil mixture ratio huskvarna 350
With Husqvarna two stroke oil it should run at 50-1, with other two stroke oil run it at 25-1 as we do not know the quaility of other oils, always try to use Husqvarna oil.
Nov 25, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Hit the throttle it quits running . it starts right up fast idle ok cuts good .wide open throttle runs fine. let it idle and hit the throttle it dies, starts right back up. has new carb kit, fuel, spark...
Conected to the rubber induction boot is the impulse hose, it is a short curled pipe, make sure this has not split and is conected to the two nipples on the carb flange.
Aug 21, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Husqvarna 350 has spark and fuel wont start just quit running while in use
1- Is the mix (gas & oil) right? If its 2-cycle,check the manual.
2- Is the choke set?
hope this helps
Jan 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Saw runs fine for about 15 minutes,then the idle speeds up,then it dies,almost like it is flooding
Do aclean or overhaul of all fuel components.Change the spark plug or the coil aka=spark plug cable.But if your saw in lees the 2 yrs you need to follow the starting guide in order to avoid flooding.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 11, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
My Husqvarna 350 chainsaw won't stay running. Changed spark plug and fresh gas. Please help if
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Husqvarna Garden
Husqvarna 350 geting fire and gas but wont start
Have you tried cleaning the air filter? The carburetor fuel inlet may have screens plugged with sawdust as well. If you have spark and fuel and AIR you should get fire(combustion)
Frank
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 350 wont stay running?
ok,  The choke is used to change the air/fuel mixture by "choking" off the air that goes to the carburator.  The choke is only used to get the motor running in cold temperatures.  Once the motor is started, the choke must be opened or the motor will flood and stall when you open the throttle.    I hope this solves your problem.  Best wishes, Michael Mittelsdorf
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
557 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
