Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
No video, tried pwr supply, tried PCI video, disconnected everythign, tried memory
  • 30 Answers
I dealt with this sort of problem with emachines, end result is i had to replace the board.
Posted on Feb 04, 2010
Yellow light on the power button of my Dell Optiplex GX520. I've tried: 1. Replaceing the power supply 2. Replacing the CMOS battery 3. Removing and reinstalling the RAM memory. 4. Replacing the...
A solid orblinking Amber power button indicates a voltage problem. This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Sep 18, 2011 | Dell OptiPlex GX520 PC Desktop
My hp 7060n won't pwr on. I checked the ps it test
I don't think you know what you are doing. No computer will boot without memory! And no mo bo will work without the 4 pin connector being attached to mo bo along with the 20/24 pin mo bo connector..
Listen, keep it simple and just plug in another known working ps to see if unit works. If it still does not work, then your issue could be corrupt bios, bad hard drive, corrupt OS, bogus peripheral, bad memory.
Sep 16, 2017 | Computers & Internet
Dell Dimension C5100 Yesterday it was fine and today it turns on but no visual on the screen. Changed monitor that wasn't it, disconnected the video from the on board video output and installed a pci...
you need to open cpu cabinet. Open back cover of cpu then refix the RAM memory. Pull cmos cell from motherboard for 10 minutes then put it back then all settings defaults. Make sure RAM is working fine. Try with another RAM .If you use 2 RAM memory then check with only 1 RAM 1 by 1. Open processor fan and processor then put it back . Clean dust from all parts . Reconnect both connection to harddrive. Make sure motherboard don't touch the cabinet. Remove pci card if any reattach vga card if you use pci vga card.Pull cmos cell cell from motherboard for 10 minutes then reconnect it.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Does not boot
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
May 08, 2010 | ASUS P5RD1-VM Motherboard
Everex GA3400 no video, no BIOS splash, nothing. Install PCI card
First look for a CMOS battery on the motherboard. If found, disconnect the battery and also disconnect the power cables from the system.
Wait for about 10 minutes and then reconnect battery.
Turn it on. If it remains same, try to re-seat memory modules and let me know if you get any beep sound when you turn on the system
Feb 18, 2010 | Everex GA3400 PC Desktop
Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Dec 28, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
System wont turn on and there is a solid green light at the top of the mother board of my gateway 310 pc replaced batt on motherboard and it still wont turn on.
hello, this be caused by several things , i am assuming your are okay with opening up a PC since you have already changed the onboard battery.
here are few things you can try to further troubleshoot:
1: though the ligh on motherboard is on, power supply can still be faulty, so lets test that with a paper clip trick,
follow this link there are pictures and very clear instructions: http://www.ehow.com/how_4732521_test-desktop-power-supply.html
if power supply is bad, well then you know what to do... change it.
if the power supply is good:
2: remove all the RAM (memory) chips from motherboard and plug the power cable back in and observe the response (you may or maynot hear THREE beeps) now plug in memory chip and try powering up and try with one chip at a time...if PC boots up with any of the chips in it you knkow you have a faulty memory.
if that didn't work:
3: with everthing put back together try disconnecting just the hard drive and power it to see if you see BIOS screen.
if not:
4: many time this worked for me with Gateway PCs, reseating CPU in its slot but only do it you feel confident doing it because you can end up with a GIANT door stop if any of the pins on the CPU are/is damaged.
you would need some thermal-paste to go back on between CPU and heatsink.
if that didn't work..i think you are up to buying new PC.
let me know if you need more help or not clear about anything...
good luck
Amar Sondhi
Dec 04, 2009 | Gateway 310S (2900621) PC Desktop
Computer cannot boot up
try replacing power supply or battery pack. If problem persists, you may have to change your motherboard.
Aug 25, 2009 | ASUS P4B266 Motherboard
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
Not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Oct 21, 2007 | Intel Motherboard
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
