Question about Frigidaire ATF6000ES Front Load Washer
I hear the motor but wont spin - Frigidaire ATF6000ES Front Load Washer
  • jonesetta24 Feb 03, 2010
    how do you get access to the drive pulley
  • Frigidaire Master
  • 8,220 Answers
It could be the drive belt has come off and the reason for that could be a warped drive pully. I have an affinity technical repair manual:
AFFINITY
Posted on Feb 03, 2010
Kenmore washing machine model 20712990 wont spin
If you don't hear a click when you close lid, replace lid switch. If when in spin, you hear motor but does not spin, replace motor coupler.
Sep 02, 2014 | Kenmore Washing Machines
2406026 fm54
Dryer will not spin, but can you hear the motor start when the button is pushed? If you hear the motor then the belt is probably broken. If you cannot hear the motor, then open the lid and check to see if there is a belt in place. A second cause for not dryers spinning are misaligned door switches. Shut the door and if it does not spin. Carefully hold the door switch closed by hand and see if does spin (for a second). This test will show that the door switch is working, but that the door is not closing the switch and that is it probably misaligned.
Jan 05, 2014 | Kenmore Dryers
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Washer wont spin
Sounds as though the idler on the back of the machine is seized.Remove the back panel and possibly free it up or replace it.
Dec 18, 2012 | LG WM2487H Front Load Washer
Wont play
If its not a power problem, notice that the servo motor is spinning or trying to spin with a disc in the tray.
-listen carefully for a high pitch or whinning sound of the motor.
-do you have a reading on the screen? No disc or reading disc?
One of the above can be:
1- a defective laser (it wont illuminate)
2- a broken flat cable to the laser (you wont hear clicking sound when reading)
3- a bad servo motor that can not reach its speed to read the disc (has to spin at a very high speed)
Hope you can solve the problem, succes
Aug 27, 2010 | Apex Digital Televison & Video
GE profile washer not spinning model number wnsr3120w0ww
Do you hear the motor going? If you do, I am sorry to say it is your transmission on your washer. The website link below will confirm this if you hear a motor going. If you don't hear a motor then it could be your motor. It is very expensive to replace, I am sorry to say. The expense of the transmission is $260 plus or minus with labor. http://forum.appliancepartspros.com/washer-repair/13251-ge-profile-washer-fills-drains-agitates-but-wont-spin.html
Dec 06, 2009 | GE Washing Machines
My druer is heating but the drum wont spin
either the motor is defective or the drum belt is broken or off the pulleys, if you can't hear the motor start and run w/o belt attached and it just buzzes the motor start cap could be bad
Sep 30, 2009 | Dryers
Machine wont spin
first check the motor bushes sounds like they are worn,take out and replace them,they cost about £10.00 for the set and easy to replace.
Jul 07, 2009 | Washing Machines
Washer wont spin out Washer wont spin I can here power to motor model#VWXR4100T6WB
You problably hear the drain motor. The most likely cause for this is a faulty lid switch.
Nov 08, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
