Question about MTX 610CM Speaker
Can't get face plate off of MTX 610CM ceiling speakers
I have a MTX 610CM ceiling speaker that was installed. I am redoing the room it was in and can seem to get the face plate off to unscrew the clamp. How do I do that?
  • 382 Answers
Its a pain, espicially if the grills were painted before installation.
In the industry we use a "grill puller" which is nothing more then a wire hook with a loop for your finger.
If the holes are big enough bend a paperclip into a hook, grab it with needle nose pliars and pull the grill through the hole near the edge.
If it doesn't fit then use a small pointed knife or awl, stick the point in a grill hole around the egde and pull it down a bit, work your way around until you can grab the grill with your fingers.
Let me know if you need anymore guidance......be careful I've replaced alot of destroyed speakers!
Cheers,
Kevin
Posted on Feb 03, 2010
Testimonial: "Yes that worked great!!! Thank you!"
How do i choose surround sound speakers to go in my ceiling?
Go to any store that sells electronics and audio products, they will be able to guide you towards the correct speaker purchase for you needs.
Dec 01, 2016 | Audio Players & Recorders
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Mar 25, 2011 | MTX TS551022 Car Speaker
Where is best to install celling speakers?
First, you must determine if the primary purpose of audio in the room is: 1.creating a soundstage at one end that is optimal for a primary listening position at the opposite end 2.uniform coverage for background music.Usally the purpose is more about coverage than creating a soundstage. With that in mind, you are usually better off putting the speakers along a line that extends down the center of the room along the room’s longest length. Then, position the speakers so that they divide the room into three equal parts as long as the distance between the speakers is not more than the height of the ceiling.
Aug 15, 2010 | Hitachi Audio Players & Recorders
Aug 12, 2010 | Fellowes Audio Players & Recorders
Home speakers
1st of all i would take a multimeter and test each wire to make sure you have a connection after this i would use any amplifier connecting 2 speakers at a time locating each one and then label the cables then from there buy a suited amplifier for your needs and away you go
Sep 11, 2008 | Wave Audio CS801 Speaker
Converting 2 channel amplifier to 2.1 amplifier
it is not availlable to do such convertion.
Jul 05, 2008 | Audio Players & Recorders
Remove screen on MTX HT625AC ceiling speaker
as far as i know the tweeter is angled in the mount it does not look like the speaker can be angled as it appears to be fairly standard ceiling unit.
but the cover looks like a push on so maybe very careful levering might work.
Apr 20, 2008 | MTX HT625AC Speaker
MTX 610CM Speaker Logo
82 people viewed this question
Top MTX Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MTX Audio Player and Recorder Expert? Answer questions, earn points and help others
