Question about Hilti 3431126 SF 144-A CPC Drill/Driver
Hilti dd 130 chuck i need to know the correct proceed ure for removing it. from someone who has done this or direct me to the pdf repair manual in de or english thanks. Rob C
    Sniper:
  • 61 Answers
Hi Rob. If you send me an email I can send you the full parts diagram (exploded view) pdf.
paul@wysehire.gi
www.wysehire.gi
Posted on Mar 04, 2010
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
Where can i get parts for the hilti DD 100
you can try going directly to Hilti at their site at Hilti.com and find a service/parts center close to you. I would suggest calling them at 1-8000-879-8000 and asking for the information. Let me know if you need more assistance.
Mar 07, 2012 | Drills
I require a user manual for a hilti dd 160 e diamond drilling rig
I would suggest either going to their site at hilti.com and see if the manual is available or calling them direct at 1-800-879-8000 and asking them to send it to your email.
Jan 24, 2012 | Drills
I need a new chuck and rubber covers for hilti te10
you can go to hilti.com or call them direct at 1-879-8000 for the correct parts. Their customer service is excellent. Let me know if you need more assistance.
Dec 10, 2011 | Hilti Drills
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Need repair manuel for Hilti TT 52
suggest going to Hilti.com and downloading the manual or calling them direct at 1-800-879-8000 and requesting one be sent as a PDF file.
Jan 14, 2010 | Hilti Drills
How do i remove the chuck on a hilti dd100 core drill i was told you just knock out the pin but it dosnt seem to budge and its starting to get butchered
go to Hilti.com and type in your model number for an owners manual on this tool. It looks like it has a locking mechanism that you just need to pull back. Let me know if you can't find it and I will get more specific info, or you can call them at 1-800-879-8000 and speak with tech services for this
Oct 01, 2009 | Hilti Drills
Hilti TE-5 does not drill
Check the motor if the motor has power and then the gears are not working. If the motor doesnt have any power then you need to check for power. To get at the gears you are going to need to remove the chuck
Feb 18, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti 3431126 SF 144-A CPC Drill/Driver Logo
1,050 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
